Date/Time: Wed, 25 Nov 2026 21:06:19 +0000
Change from open in Quote Board
View Count: 428
| [2025-11-12 15:05:58] |
| User801402 - Posts: 25 |
Hello, i would like to have the "change from open" on a Quote Board calculated from the rth open. What is the best way to do this without affecting rest of the chartbook, especially charts. Thanks a lot Date Time Of Last Edit: 2025-11-12 15:21:22
| [2025-11-12 16:34:17] |
| John - SC Support - Posts: 48659 |
The Quote Board only has fixed items that you can use for it. There is a "Change from Open" item, but it probably is not what you are wanting since you state that you want it from the RTH Open. Refer to the following: Getting Quotes: Field Descriptions The only way to get this information and display it in a separate window like the Quote Board would be to use the "Study Summary Window". And you would need to setup a study to get what you want. Refer to the following: Study Summary Window There is the "Percent Change Since Open" study, although you would need to apply this to a chart with just the RTH in order to get what you want. Refer to the following: Percent Change Since Open For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-12 18:13:31] |
What i want to display is a list of 10 instruments with the "% from open" 1) Could it help to change instruments settings of these 10 instruments? 2) If not, does it work with a spreadsheet? 3) I open 10 rth charts and use the mentioned study summary window Thanks Date Time Of Last Edit: 2025-11-12 18:19:52
| [2025-11-12 19:23:26] |
If you want to view the "Percent Change since Open" for 10 different instruments, where the Open is the Open of the RTH, then you would need 10 different charts with the Session Times set to only be the RTH. Then add the "Percent Change Since Open" and set it to Daily. Then you will see all 10 of these results in the "Study Summary" window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-12 21:18:51] |
Thank you, this works fine. 1) Can i put in an empty row? 2) Can i switch off those row numbers at the left? Thanks |
| [2025-11-12 21:53:48] |
There are no options to put in an empty row or to switch off the numbers on the left. Note that you can include Quote information, these options are under the "Settings" menu, so you can get your quotes and this particular field at the same time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
