Date/Time: Wed, 25 Nov 2026 21:06:18 +0000
Studies/Indicators Global
View Count: 344
| [2025-11-12 06:58:24] |
| User296197 - Posts: 12 |
Hello, I have a question about the indicators. I'm using three monitors running Sierra Chart. For example, if I change the VWAP on one screen, I have to save the changes separately and then load the study collections on the other screens. Is there a way to change the indicator/studies only once?
| [2025-11-12 15:14:57] |
| John - SC Support - Posts: 48659 |
You can use the Linking options to link studies between charts, but this will mean that all charts will have the exact same studies on them with the exact same settings. Refer to the following: Chart Settings: Chart Linking >> Studies (Chart >> Chart Settings >> Linking menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
