Date/Time: Wed, 25 Nov 2026 21:06:15 +0000
[User Discussion] - disparition de la ligne qui est sous la ligne file edit chart analys etc
View Count: 375
| [2025-11-11 20:25:56] |
| User945117 - Posts: 3 |
j ai ferme par erreur cette ligne de racourci et je n arrive pas a la faire reapparaitre
| Attachment Deleted. |
| [2025-11-11 21:19:34] |
| John - SC Support - Posts: 48659 |
From Google Translate: The line below the "File, Edit, Chart, Analysis, etc." shortcut has disappeared.
I accidentally closed this shortcut and I can't get it to reappear. It sounds like you are referring to the "Chart Header". Refer to the following regarding the Chart Header: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-13 08:57:55] |
J ai ferme par erreur la ligne de raccourci pour la faire reapparaitre je suis alle dans global settings puis dans customize chart header standard et il y a deux colonnes :availableheader fields et a droite select header field que dois faire?
| [2025-11-13 16:47:36] |
From Google Translate: I accidentally closed the shortcut line. To make it reappear, I went to global settings, then to customize chart header standard, and there are two columns: available header fields and on the right, select header field. What should I do?
You need to select the items that you want to show in the Chart Header from the list in the left and move them to the list on the right. To do this, select an item on the left and then select the "Add" button to add it to the list on the left. If you want to remove something from the list on the right, then select it on the right list and select the "Remove" button. Select "OK" when you are done to save the changes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
