Date/Time: Wed, 25 Nov 2026 21:06:17 +0000
Fill Space Shading
View Count: 473
| [2025-11-11 10:14:23] |
| gambotage - Posts: 39 |
Hi there. Really quick one here. I’d like to recommend a few new DrawStyle possibilities in the platform similar to these: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle These come to mind & would be fantastic to see among the comprehensive list. For example: DRAWSTYLE_FILLSPACE_FILL_TOP/BOTTOM DRAWSTYLE_FILLSPACE_TRANSPARENT_FILL_TOP/BOTTOM I’ve seen other coders pull it off without any performance impact and would be nice to be able to offer this natively in a future version of SC. Unrelated, but on occasion I wonder if a search box would be practical for the Graphics Settings - Global/Chart lists, much like what is already available in Chart Settings. Its super handy and could save time scrolling here too. Again, thanks for the feedback Date Time Of Last Edit: 2025-11-11 10:15:03
| [2025-11-11 13:33:38] |
| Sierra_Chart Engineering - Posts: 25483 |
Draw Styles like this would not be added because they are making reference to specific chart columns. We would never add anything like this. We are not even sure how this would be done. And they are completely inconsistent with other draw styles.
| [2025-11-12 23:30:28] |
In C++ near anything is possible. I have a colleague who did it and it works just fine. Anyway would be nice if this was native but as a user I can only request to see if it's something that would be considered. Thanks again,
| [2025-11-14 03:06:19] |
Also LINESTYLE_STAIRSTEP_AT_LAST_BAR_TO_EDGE wouldn't hurt either. Add it to the list!
| [2025-11-18 14:51:47] |
| John - SC Support - Posts: 48659 |
We do not undertand what "LINESTYLE_STAIRSTEP_AT_LAST_BAR_TO_EDGE" would do. The point of the stairstep is to have a line that jumps from one price level to the next at each bar instead of just making a connecting line. If you are only drawing from the last bar to the edge, then there is only one price level, hence there is no purpose behind a Stair Step. Please give us more information on what exactly you are wanting to accomplish from this. Note that we are not saying we will do this any time soon. But we do take all feature requests. And it is best if we understand what is wanted at the time the request is made, otherwise, when we get to it later, we will not have any clue as to the intention. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
