Date/Time: Wed, 25 Nov 2026 21:06:20 +0000
Volume Profile - coloring high and low value areas
View Count: 985
| [2025-11-10 18:02:23] |
| User693935 - Posts: 12 |
Not able to color high and low value areas in volume profile 1. went through Analysis > Studies > volume by price > Settings to Settings and Imputs and Subgraphs 2. Also studied Table of Contents > Charts > Studies and Indicators > Volume by Price study > Color and Width Settings > Value area and Set tings (SG9) 3. I have been able to indentfy high and Low value areas with lines not color - must not have everything checked - In Imput and settings Draw Mode set on Volume Profilies & POC.VAN.VAL.VWAP and Highlight Value Area to Yes not sure about other settings 4. Under Subgraphs Value Area and Outling (SG9) I tried different colors Visible Draw Style Solid Line Style with no Line Label 5. There must be something in Settings and Imputs And Subgraphs that needs to be checked or unchecked. - I though I've followed all the instruchtions in The Coloring and Width Settings section of "help" Hope You Can Help |
| [2025-11-10 20:05:02] |
| John - SC Support - Posts: 48659 |
There is no option in the Volume by Price study to color just the Value Area High and Value Area Low bars, if that is what you are wanting to do. You can color the entire Value Area, and you can setup Extension Lines that project out from the Value Area High and Low. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
