Date/Time: Wed, 25 Nov 2026 20:52:01 +0000
VOLUME:RANGE TICKS
View Count: 370
| [2025-11-09 17:13:46] |
| rebeccaemme - Posts: 42 |
Hello, Yesterday I asked for help creating a study to display Volume : Range Ticks as a Numbers Bars calculated value. The support team kindly referred me to this page: Using the Basic Arithmetic Studies However, it seems that it is not possible to create this study because there is no way to directly obtain the simple Range in Ticks for each bar. Could you please advise how I can get the Volume : Range Ticks result as a numeric value for each bar in the Numbers Bars? Thank you for your assistance. |
| [2025-11-09 18:38:44] |
| User431178 - Posts: 910 |
However, it seems that it is not possible to create this study because there is no way to directly obtain the simple Range in Ticks for each bar. It's possible - two solutions in attached chartbook. |
| [2025-11-09 19:17:27] |
but I can't get the number value of Range in Ticks of every candle
| [2025-11-09 20:58:08] |
Look at the first chart in the chartbook. There is a study that gives the high and low in ticks, then uses arithmetic study (difference) to get range in ticks. You can set the difference study to show as Value on low if you want to see the numbers under the bar. |
