Date/Time: Wed, 07 Oct 2026 15:21:57 +0000
Trade Activity Log Questions
View Count: 315
| [2025-11-09 15:42:43] |
| user_xyz - Posts: 526 |
Question in Trade Activity Log -> Trades I know you all recently made some naming convention updates / changes. Looking across a few SC instances I see 0.00 in the following columns Highest Cum P/L, Lowest Cum P/L, Max Runup and Max Drawdown. Are you all still working on this or something else going on? Thanks |
| [2025-11-09 18:49:43] |
| Sierra_Chart Engineering - Posts: 25093 |
There were only minor changes to those fields with naming, and some minor reimplementation. This development has been completed some time ago. Check the Cumulative Profit/Loss field. If that field is zero then these fields would be zero as well: Highest Cum P/L, Lowest Cum P/L Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-09 18:50:15
| [2025-11-10 12:20:53] |
Every field has values as expected, except the 4 listed above.
