Date/Time: Wed, 25 Nov 2026 20:51:50 +0000
Wrong data set
View Count: 353
[2025-11-07 18:10:23]
cmack1011 - Posts: 201
I used the "Export bar and study data to text file" function for a chart in a chartbook from today (Nov 7, 2025) but the TXT file that is created is from a chart dated May 12, 2025? Please advise. I will try to attach the file here. Thx
attachmentORGO [CB-D][M] 1 Min #8_GraphData.txt - Attached On 2025-11-07 18:10:09 UTC - Size: 6.44 MB - 119 views
[2025-11-07 18:36:50]
John - SC Support - Posts: 48658
We do not understand the issue. The data starts at May 12, 2025 at 03:05:00 and ends at November 7, 2025 at 11:59:00.
This means that the chart you are exporting has data going back to May 12, 2025.
[2025-11-07 19:29:22]
Ah, I figured it out.
Thx
