Date/Time: Wed, 25 Nov 2026 20:51:53 +0000
Formatting Bar Duration Study(HH:MM:SS to MM:SS)
View Count: 407
| [2025-11-06 09:55:23] |
| User140464 - Posts: 7 |
I'm using the time duration study on my footprint charts As you can see in the attached screenshot, the study currently displays the duration in the HH:MM:SS format. Is there a way to customize the time format to show only MM:SS? |
| [2025-11-06 15:23:01] |
| John - SC Support - Posts: 48658 |
There is not a built-in way to change the way the time is displayed. Depending on the study you are using, if it is available in the ACS_Source folder under your main Sierra Chart installation folder, then you could modify the source code to only display what you want. Refer to the following: How to Build an Advanced Custom Study from Source Code https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
