Date/Time: Wed, 25 Nov 2026 20:51:50 +0000
Large Volume Trade Indicator - does not appear for GC contract but appears for ES
View Count: 464
| [2025-11-06 00:43:37] |
| User456487 - Posts: 1 |
Hello, I have been trying to enable the Large Volume Trade Indicator on GC with Interactive brokers with the denali feed enabled alongside. The indicator does not appear, but on the ES chart it appears. FYI: the Interactive brokers feed does display an "M" on top indicating the data stream works fine. Thanks, Ram. |
| [2025-11-06 15:18:17] |
| John - SC Support - Posts: 48658 |
Please check the setting for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Intraday Data Storage Time Unit". This needs to be set to "1 Tick" for the Large Volume Trade Indicator to work. We think you already have this set correctly since ES is working, but we want to double check it. Next, on the GC chart, set the "Volume Threshold" for the "Large Volume Trade Indicator" to "1". See if you get the indicators in this case, which you should for every price level. If they are there, then you would need to evaluate the threshold you have set and see if that is too high. If the above all fail, then get the chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
