Date/Time: Wed, 25 Nov 2026 20:51:57 +0000
Draw Delta Profile with Hotkey
View Count: 663
| [2025-11-05 08:59:32] |
| aygh - Posts: 22 |
I just watched a video by Orderflow Labs where they created a main window button that draws Delta profile (https://www.youtube.com/watch?v=7skH9kM-lsE). Will it be possible to create a hotkey instead of the button?
| [2025-11-05 15:00:16] |
| John - SC Support - Posts: 48658 |
The "Draw Volume Profile" has a keyboard shortcut option for it. It is under the keyboard shortcuts in "Tools >> Draw Volume Profile". Refer to the following: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-05 15:00:53
| [2025-11-06 03:45:18] |
| aygh - Posts: 22 |
This would just draw the Volume Profile. I want to draw the Delta profile like in attached
| [2025-11-06 15:20:02] |
That is done by setting a proper Configuration for the Drawn Volume Profile. Refer to the following: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
