Date/Time: Wed, 25 Nov 2026 20:51:58 +0000
Sierra chart SSD and hardware questions
View Count: 514
[2025-11-04 14:45:57]
kero kero - Posts: 8
I'm on the verge of getting a new PC and recently i came accross a post on the forum where the support told a member that it's better to have an SSD and use the SSD. My question is do you have any SSD that you would recommend? To put sierra chart on ?
I've thought of a 2T samsung SSD that's quite popular.
Also for my new PC i've thought of an i9 intel CPU; is this necessary or not? And regarding the RAM i currently have 32GB would it be great to get to 64GB?
Best regards,
Kerozene.
[2025-11-04 14:48:45]
Yes absolutely use a SSD. However, we would think these days, all computers would have those instead of a hard drive. You will want to get an NVME SSD.
Samsung has a lot of different models. You would definitely want one, that has high endurance.
Date Time Of Last Edit: 2025-11-04 14:48:56
[2025-11-04 15:02:12]
For portability i've thought of an external one, would that work or would you advise against for permission problems, etc?
[2025-11-04 15:06:11]
John - SC Support - Posts: 48658
Do not use a portable drive for Sierra Chart. There is a lot of reading and writing of data, and a portable drive will be limited by the connectivity speed of the port you are using. An internal drive will have much better speeds.
[2025-11-04 15:59:19]
But on that same post a guy says that we should have a drive with nothing else but sierra on it, this would mean to build my new computer with 2x internal drives am i correct?
Trading is taking more and more space in my life so i'm totally okay with doing it. But what should i do with that comment "It's better to have one SSD for sierra only and nothing else on it"?
Best regards,
& Thank you for your time,
Kerozene.
[2025-11-04 17:31:21]
Yes, if you can do this, then this is best.
This is what the 2 drive recommendation is about. One drive for Windows and everything else you use, then another drive just for Sierra Chart. If you are not using a Laptop, then having multiple drives is not difficult to do.
[2025-11-04 19:02:59]
Thanks guys, that totally answers my question ! Have a nice day & thank you again.
