Date/Time: Wed, 25 Nov 2026 20:51:46 +0000
(ACSIL) More information on DRAWING_ORDER_FILL and DRAWING_ENTRYEXIT_CONNECTINGLINE
View Count: 333
[2025-11-03 19:06:04]
skalaydzhiyski - Posts: 139
Hi SC,
Can you point me to any example of the minimum required fields that need to be populated for DRAWING_ORDER_FILL and DRAWING_ENTRYEXIT_CONNECTINGLINE ?
I am implementing a custom order fills study aand would love to find out if these can save me some time.
All the best
[2025-11-03 19:09:33]
These cannot be used from ACSIL. They definitely will not work properly.
[2025-11-03 19:27:15]
Is there any reason why they were omitted from the feature set exposed to developers through ACSIL ?
[2025-11-03 22:11:59]
These are not standard drawings, and there has to be more work to make them available for ACSIL. This is not really practical with the way they are implemented internally. You can draw lines and other type of objects, using the different Marker drawings.
Date Time Of Last Edit: 2025-11-03 22:12:27
