Date/Time: Wed, 25 Nov 2026 21:36:13 +0000
[User Discussion] - Is it possible to plot Asia, UK and NY sessions as their own bars?
View Count: 887
| [2025-11-03 15:56:29] |
| User461027 - Posts: 11 |
Hello-- I was able to use your support board suggestions to successfully make a daily chart into a chart that displays one bar for RTH (NY open to close) and ETH (globex open to NY open). This was great. I'm curious if I could take it one step further. I would like to be able to plot one bar for each of the following sessions: 1. Globex open to Asia open 2. Asia open to UK open 3. UK open to NY open 4. NY open to NY close. I think I've seen it is possible to plot these on one TPO chart, but I'd love to get it set to where I could have that as session candles. Thank you in advance for your help! |
| [2025-11-03 16:37:53] |
The only way to do this for a candle chart would be through a custom study. Refer to the following: ACSIL Interface - Custom Chart Bars https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-03 16:43:31] |
Thank you so much!
| [2025-11-26 21:43:31] |
| User682080 - Posts: 9 |
How is this accomplished? I was able to use your support board suggestions to successfully make a daily chart into a chart that displays one bar for RTH (NY open to close) and ETH (globex open to NY open). This was great.
Date Time Of Last Edit: 2025-11-26 21:47:50
| [2025-11-26 21:52:49] |
Ok--in chart settings session times: Intraday session start: 930 intraday session end: 1700 use evening session: YES evening start 1800 Evening end 092959 Then in bar period put bar period value 0-1330-0 That should give you RTH and ETH bars...I haven't made one yet for different sessions but will post if I get around to it... |
Attachment Deleted. |
| [2025-11-27 00:51:25] |
Thank you very much!
| [2025-11-29 15:24:10] |
| Sawtooth - Posts: 4362 |
Actually, any bar period from 0-930-0 to 0-1439-0 will work.This is because the Evening session in this example is 930 minutes, and any minute duration >= 930 or < 1440 (24 hrs) will use the Day session start time for a new bar. This concept should work for any two sessions. But it can't create 4-session bars, as the OP wanted. |
