Date/Time: Wed, 25 Nov 2026 20:52:11 +0000
[Programming Help] - GDT_KAGI GraphDrawType for custom study
View Count: 363
| [2025-11-02 22:50:00] |
| davidtrades - Posts: 2 |
Hello, I can't seem to find any documentation or an example (unlike most other studies which are located in ACS_SOURCE) for how to use this draw type correctly. Any guidance would be very appreciated. |
| [2025-11-03 15:42:17] |
| John - SC Support - Posts: 48658 |
The following is the one item that uses that draw style: Kagi Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-03 20:33:13] |
I see, I would like to make a custom version. Is there a way I could see the example of how that study is using it? Thank you |
| [2025-11-03 21:39:07] |
That study's source code is not available. In looking at it, we see that the ability to use the "GDT_KAGI" is not available through ACSIL, and this is not something that will be made available.
