Date/Time: Wed, 25 Nov 2026 20:52:05 +0000
experiencing the following issue with the study display
View Count: 490
[2025-11-02 13:50:43]
User437588 - Posts: 93
Hello
I am experiencing the following issue with the study display in the chart. When I display the study, I set the view width as in Chart 1. The data feed must be activated.
As soon as I hide the study and then show it again later, the view width is no longer set as in Chart 1. I have checked all the settings in the scale settings, but SC does not save them. Please compare Chart 1 (this is how the settings should remain) and Chart 2. What is the problem here? Because every time the study with indicators (e.g., RSI, Stochastic) is hidden and then shown again, it has to be readjusted.
Thank you very much for your help.
The display width should remain the same!
The display width should remain the same. As soon as the study is hidden and then shown again, the display of the indicators is wider and the candlestick chart is smaller.
What setting do I need to change so that the width remains as in Chart 1
imageChart 1.jpg / V - Attached On 2025-11-02 13:49:46 UTC - Size: 216.33 KB - 141 views
imageChart 2.jpg / V - Attached On 2025-11-02 13:49:50 UTC - Size: 242.15 KB - 220 views
[2025-11-03 14:43:42]
John - SC Support - Posts: 48658
There is no option for this to stay the same. When you hide a study and then show it again, the region height is set to the default.
[2025-11-04 09:30:40]
That surprises me, because a few updates ago, that was always the case. The range height was not reset to the default value.
Because if several studies are used, e.g., only the volume profile, it doesn't matter, but if you use the RSI or MACD, the range height becomes smaller after fading in and out. This is a disadvantage when something needs to be checked quickly and the markets are very dynamic.
I am very sure that this range height was maintained before a few updates.
Perhaps there is a technical way to program SC so that the range height remains as desired.
Thank you very much.
[2025-11-04 14:36:27]
It has never been the case that the height of a region has been kept. If this was occurring, then we do not know the reason why - programmatically it should not be the case.
We have noted this as a Feature Request. We can not say when we would get to any particular item.
