Date/Time: Wed, 25 Nov 2026 20:52:09 +0000
Drawings Hidden Under Market Depth Historical Graph
View Count: 470
| [2025-10-31 12:09:27] |
| User972483 - Posts: 12 |
Hello, I am using the Market Depth Historical Graph on my chart, and whenever I try to draw something (for example, a line or rectangle), the drawings appear underneath the Market Depth Historical Graph and are not visible. Is there a way to display drawings on top of it, or to move the Market Depth Historical Graph to the lowest layer in the chart? Ertan YILMAZ |
| [2025-10-31 13:59:44] |
| John - SC Support - Posts: 48658 |
Refer to the following setting and the one below it, that control where the drawings are put: Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
