Date/Time: Wed, 25 Nov 2026 20:52:10 +0000
Market Depth Combine Is Overlapping Some Recent Bid/Ask Numbers on GC DOM
View Count: 688
[2025-10-30 23:38:01]
User261655 - Posts: 57
The "Market Depth Combine Increment In Ticks" feature is overlapping some numbers in the recent bid/ask columns on my GC DOM. This occurs regardless of scale setting, but only with gold. Indexes work fine. Screencap links below. Thanks!
https://www.sierrachart.com/image.php?Image=1761867034426.png
https://www.sierrachart.com/image.php?Image=1761867305467.png
[2025-10-31 13:24:28]
John - SC Support - Posts: 48658
What is the Tick Size of that chart set to?
[2025-10-31 13:32:45]
Tick size is 0.100000
[2025-11-03 18:47:42]
Make sure you are using the right configuration as documented here:
Global Trade Settings Windows: Combining Price Levels for Market Data Columns in the Chart/Trade DOM
And make sure this option is enabled as well:
Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu)
And disable custom Symbol Settings:
Global Symbol Settings: Disabling Custom Symbol Settings
[2025-11-03 23:15:39]
I followed all of those steps, but it didn't seem to help
Just to be sure it wasn't error on my part, I did completely fresh SierraChart install, and the issue happens there, as well. Again, only for GC.
Screencap from the new install:
https://www.sierrachart.com/image.php?Image=1762211631962.png
[2025-11-04 15:27:34]
We are not able to reproduce the problem.
Try removing the Trade and Current Quote Symbol from the chart:
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
Date Time Of Last Edit: 2025-11-04 15:27:40
[2025-11-04 15:48:10]
The issue remains, even after removing the Trade and Current Quote Symbol.
If I switch to MGC, the overlapping text goes away. But with GC -- and only GC -- it continues.
[2025-11-04 16:23:02]
We are not able to reproduce. We do not know what the issue is in your case. It does not make any sense. Our recommendation is just not to use the combining functionality.
[2025-11-04 19:01:08]
Actually we do see it, when we combine two levels together. Not a greater number. We will look into this.
