Date/Time: Wed, 25 Nov 2026 20:52:09 +0000
Trade Activity Log Disabled
View Count: 828
| [2025-11-02 07:11:52] |
| Sierra_Chart Engineering - Posts: 25483 |
We do not know what that means "not playing well".
| [2025-11-02 09:00:04] |
| User286338 - Posts: 16 |
When i open my trade it's appreaning on both how can i remove the orders orders from the distribution chart.
| [2025-11-02 15:04:29] |
Can you tell me how to change the colour of order fills on the chart
| [2025-11-03 14:48:09] |
| John - SC Support - Posts: 48658 |
Are you referring to the position showing on multiple charts? This is normal. If a chart is for the same symbol and has "Trade >> Chart Mode On", then any positions that are open will display in that chart. Refer to the following: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM Can you tell me how to change the colour of order fills on the chart
Refer to Item #12 at the following link: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
