Date/Time: Wed, 25 Nov 2026 16:39:20 +0000
Volume Profile
View Count: 431
| [2025-10-29 16:01:07] |
| User818481 - Posts: 14 |
I would like to have 2 volume profiles on the same chart. One butted up against the right side, and the other offset just to the left. Everything I have found suggests using the Volume by Price Study, but there are no options in the study settings to offset the volume profile. I updated to the most current version of SC, after the update is show 54343 as the current version. A few tutorials made it seem like I did not have the offset settings because I had an older version. Thank you |
| [2025-10-29 16:02:57] |
This has nothing to do with version - the functionality you are looking for has been in the system for a very long time. Refer to the following for how to do this: Volume By Price Study: Allow Side-By-Side Profiles on Right Side For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
