Date/Time: Wed, 25 Nov 2026 16:39:27 +0000
Update of User Contributed Studies – missing DLL file
View Count: 447
| [2025-10-29 08:57:56] |
| User993113 - Posts: 83 |
Hello, I am trying to update the User Contributed Studies that I currently have saved in the Data folder. However, on the page User Contributed Advanced Custom Study System Source Code I can only find .cpp source files. When I go to Analysis → Build Custom Studies DLL and try to build them, I get the following message: “None of the selected source files contains the SCDLLName() line…” Could you please explain where I can find the corresponding .dll file, or how to correctly update the existing User Contributed Studies to the latest version? Thank you in advance for your help. |
| [2025-10-29 12:56:33] |
| Sierra_Chart Engineering - Posts: 25481 |
You just need to add this line of code to one of the source code files: “None of the selected source files contains the SCDLLName() line…” Refer to this page: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
