Date/Time: Wed, 25 Nov 2026 16:39:10 +0000
how to move the Volume at price threshold alert over number bars?
View Count: 491
[2025-10-28 14:23:41]
User172061 - Posts: 36
hi there. so my number bars, in my studies, are located under the volume price threshold, but its drawing it under the number bars. id really like it to be over the bars so i can see where its at, its hard as heck to read when its behind it. am i doing something wrong?
[2025-10-28 15:57:03]
The order in which the studies are in the list of studies defines the order they are drawn in, going from the top to the bottom (bottom are the last drawn, so they are the most "on top").
Make sure you have the study you want to display above another further down in the list.
We are a bit confused by one thing though, the Volume at Price Threshold Alert V2 is setup (by default) to print squares off to the side of a bar, so it should not be drawing in a way that covers the Numbers Bars at all. Are you using the "Volume at Price Threshold" alert (not the V2 version)? Or are you using a different marker type for the subgraphs?
[2025-10-28 16:03:46]
that worked! i misunderstood the order they print. i switched it from the default to Right Arrow. it makes it easier for this old man to see :)
