Date/Time: Wed, 25 Nov 2026 16:39:04 +0000
Trade Window Issues
View Count: 599
| [2025-10-28 13:04:13] |
| Smnitro1 - Posts: 29 |
Hello, My trade window for chart P&L reverts back to Points when set to currency. Also, points value on MES chart is 4x the actual value. 1 point P&L on chart is showing 4 points on position line. |
| [2025-10-28 14:33:03] |
| Sierra_Chart Engineering - Posts: 25481 |
We need precise information on the sequence of events: My trade window for chart P&L reverts back to Points when set to currency.
Describe exactly how this is happening. When you change it to Points, and when it is changing back to a Currency Value. Also, points value on MES chart is 4x the actual value. 1 point P&L on chart is showing 4 points on position line. Refer to:Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-28 14:58:12] |
I open the Sierra Chart app. Under trade tab I click Open Trade Window for Chart. P&L window shows Points instead of Currency. Chart settings-Trading- Profit/Loss format is set to Currency Value. Do I need to change this on every chart? I don't see a global option. When opening a trade, point value on trade window shows points but it does not match the charts. Every 1 point move shows 4 points in the trade window. Is there a multiplier I am missing in settings? This is currently a Sim but I want to correct these issues for when I trade live. I went through the documentation you provided but I haven't found a solution. Please advise. Thanks! |
| [2025-10-28 16:05:33] |
Yes, this has to be changed per chart. There is not a global option to set this. When you have this occur, please get us an image showing the "Chart >> Chart Settings >> Trade" tab along with the Trade Window for that chart. When opening a trade, point value on trade window shows points but it does not match the charts. Every 1 point move shows 4 points in the trade window. Is there a multiplier I am missing in settings? This is currently a Sim but I want to correct these issues for when I trade live.
We need an image for this as well. We need to see the position line on the chart and the Price Ladder along with the Trade Window so that we can compare the information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-28 20:51:12] |
So after doing the math. I found that the point value is showing in Ticks and not Points. Even though is has a "P" suffix after the value. A prior trade in the trader log activity shows $235.00 and 47.00. This is the number of ticks for the trade. Not sure why it is showing in ticks. How do I change this to Points?
| [2025-10-28 21:32:33] |
Refer to the following: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-29 16:06:58] |
Please see the attached image. On the trade window, D:217.50C is correct. 43.50P is in ticks. All settings in Chart Settings are correct for this MES symbol. I would like to know how to show the correct point value for the profit instead of the tick value being shown. It also has a "P" suffix for some reason. I have read the documentation you provided. Please advise. https://www.sierrachart.com/image.php?Image=176175360316.png |
| [2025-10-29 17:02:47] |
We need to see an image of the "Chart >> Chart Settings >> Trading" tab with the "Profit/Loss Format" setting visible.
| [2025-10-29 17:51:13] |
sorry about that. Here you go. https://www.sierrachart.com/image.php?Image=1761760082269.png |
| [2025-10-29 18:14:50] |
The "Profit/Loss Format" is set to "Currency Value (C) & Points (P)", therefore that is what you are seeing in your Trade Window. Set the "Profit/Loss Format" as you desire. Refer to the following: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
