Date/Time: Wed, 25 Nov 2026 16:39:21 +0000
question: Number of Trades per Bar for SPX Index Chart
View Count: 377
[2025-10-28 03:18:24]
User708340 - Posts: 21
Hello
My understanding is that the SPX is just a calculated index, not a directly tradable instrument itself. If this is correct, it shouldn't have "trades" or "volume" data directly associated with it.
Question: Does the "Number of Trades per Bar" Chart actually work for an SPX index?
If it's not correct to use "Number of Trades," am I limited to only using time-based charts (e.g., 1-minute, 5-minute, Daily) for the SPX index?
Thank you for any clarification!
[2025-10-28 15:24:17]
The SPX index updates every 1 second. Each update is counted as 1 trade and 1 volume. So you can use non-time based bar periods based on that information.
