Date/Time: Wed, 25 Nov 2026 16:39:27 +0000
Server Side Bracketed Orders - Teton
View Count: 940
| [2025-10-27 12:18:49] |
| 7ravis - Posts: 3 |
Good morning, I've read through some other support threads on this issue and still looking for clarity. When I enter a bracket order - 2 targets, 1 stop, stop moves to break even on target 1 fill - these are held on the server with Teton and will fill and be managed on the server when my own PC system is shut down. Is this accurate? I ask because last night the stop did not adjust after target 1 hit. I checked my general trade settings and Use Server Side Bracket Orders was set to no, while Use Server Side OCO Orders was set to yes. They are both now set to yes, so my expectation based on what I have read is that going forward my orders should be held on the server side and process as expected. Is this true? Thanks in advance. |
| [2025-10-27 13:27:01] |
| Sierra_Chart Engineering - Posts: 25481 |
Yes so long as you are not using any client-side order types: When I enter a bracket order - 2 targets, 1 stop, stop moves to break even on target 1 fill - these are held on the server with Teton and will fill and be managed on the server when my own PC system is shut down. Is this accurate?
Although Move to Break even functionality is not managed on the server: Order Types: Sierra Chart Management of Trailing Stop and Chase Orders You have to keep Sierra Chart running for that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-27 14:09:38] |
| 7ravis - Posts: 3 |
Ok, thank you. So if I shut down after placing my bracketed order the stop would just remain at the level set when the order was placed and the target limit orders placed would be managed server side.
| [2025-10-27 15:55:58] |
Correct.
