Date/Time: Wed, 25 Nov 2026 16:39:17 +0000
volume by price显示灰色,想要设置成彩色
View Count: 460
| [2025-10-27 03:21:32] |
| User665768 - Posts: 1 |
如何设置成彩色的volume by price图像
| [2025-10-27 15:20:50] |
If you have colors set to something other than gray, but the gray is all you are seeing, then this is due to the data being too close together. You would need to change the Scaling of the chart, or modify the "Ticks per Volume Bar". Refer to the following: Volume By Price Study: Ticks Per Volume Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
