Date/Time: Fri, 25 Sep 2026 15:56:38 +0000
Horizontal Lines Study
View Count: 428
| [2025-10-27 00:06:06] |
| User303857 - Posts: 199 |
Would it be possible in the distant future to have the Horizontal Lines study be able to anchor to an another study for the starting reference point scale. For example to have it anchor to the RTH open or globex open? And, have the mid point of the 40 lines be set to that so half of the lines would be above/below the anchor scale point? Using something similar with a lot of (+10) study sub graph add lines combined with 10+ study sub graph subtract lines. At different distances.. +100 +225 + 300 ticks. All based off a 10 am horizontal line for the starting price scale amount. The current study locks in the same scale increments and you have to key in the starting reference price number for example 25000 to make use of it and then re key a new level for a change, rather than having it based on another study. A time line or the open high low for time period. If half of the 40 lines could be below that point and half above it would be more useful. Thanks Thanks Date Time Of Last Edit: 2025-10-27 00:43:52
| [2025-10-27 15:16:41] |
| John - SC Support - Posts: 48013 |
We have noted this as a Feature Request. We can not say when we would get to any particular request.
| [2026-06-25 17:25:45] |
The "Horizontal Lines at Increment" study has been updated to allow you to set the starting value based on another study's subgraph. Additionally, there are new options to define the number of lines to draw, and to draw lines above and below the starting value. Refer to the documentation for this here: Horizontal Lines at Increment These changes will be in the next Pre-Release (v 2925). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
