Date/Time: Wed, 25 Nov 2026 16:39:21 +0000
Asking for help to apply color on the *not yet* developed area of the chart
View Count: 579
| [2025-10-25 11:17:50] |
| User293951 - Posts: 27 |
Hi! I have tried to apply background transparent color cheme to the yet undeveloped area of the chart. This was proven to be impossible so far on my side. I am running a chart only on RTH, tradig NQ contracts. The VWAP bands are drawn and of course I can do whatever I want on the already developed area of the chart. On the attached image, for example, the Region 1 (already developed) has dark green background color. This region refers to the +1SD to -1SD VWAP bands. I want to apply the same background color to Region 2, which is not yet developed. I can draw extension lines but I cannot apply any color scheme bwteeen these two lines, as I can do in Region 1. Is there any way to perform this task? Tried everything without success. I need this because the speed of execution is enormous and my eyes are getting crazy specially during the US open. Regs, PA |
| [2025-10-25 16:55:17] |
| User303857 - Posts: 201 |
Play around with it , but don't like it yet...
Date Time Of Last Edit: 2025-10-25 17:12:30
| [2025-10-27 10:44:51] |
| User688525 - Posts: 403 |
User293951, Have you looked at the "Time Range Highlight - Transparent" study in Studies8.cpp? |
| [2025-10-27 15:28:05] |
There is not a way to do this with the built-in tools in Sierra Chart. But, you can do it with a custom study. Refer to the following: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].ExtendedArrayElementsToGraph https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
