Date/Time: Wed, 25 Nov 2026 16:39:20 +0000
Daily Ask Volumes Bid Volumes
View Count: 314
| [2025-10-24 13:37:34] |
| User786183 - Posts: 5 |
Dear Sirs, I am able to view bid and ask volumes on the hourly charts, but I cannot see them on the daily charts. Is there a way to display daily bid and ask volume data in Sierra Chart—for example, for the SIZ25 contract on COMEX? Thank you in advance for your support. |
| [2025-10-24 15:04:45] |
Daily Historical Data is different from Intraday data. The daily historical data is only the Open/High/Low/Close/Volume information, so there is no Bid and Ask data. To get a daily bar with Bid/Ask information, you would need to build the daily bars from the Intraday data. To do this, set "Chart >> Chart Settings >> Data Limiting >> Chart Data Type" to "Intraday Bar Only". Then you can set the Bar Period however you want, and the data will be derived from the Intraday data only. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
