Date/Time: Wed, 25 Nov 2026 16:39:22 +0000
Display Ask/Bid Volume Ratio
View Count: 656
| [2025-10-23 18:49:59] |
| jiannisalex - Posts: 10 |
Hi, I'd like to add Display Ask/Bid Volume Ratio in my Footprint chart, but I cannot find it in Analysis → Studies → Add Study → Numbers Bars Calculated Values. What should I do? Thank you in advance Yiannis Alexakis |
| [2025-10-23 19:47:04] |
There is not an item for this in the Numbers Bars Calculated Values. We are not sure exactly the calculation you are looking for, but refer to the following for one possible study that will give you what you want: Bid Ask Volume Ratio Then you can use the "Numeric Information Reference" study to display the numbers from that study in the same style grid as the Numbers Bars Calculated Values. Refer to the following: Numeric Information Reference If you are wanting a different calculation, then let us know and we will point you to what you need to do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
