Date/Time: Wed, 25 Nov 2026 16:39:23 +0000
Change Chart Number
View Count: 418
[2025-10-23 17:58:54]
John M - Posts: 189
How do you change the number of a chart in a chartbook?
Have looked all thru the Chart menu and can't find it.
It's in there somewhere but I don't know where.
thank you
[2025-10-23 19:39:06]
There is not a way to directly change the chart number of a chart. The only way to do this is to duplicate the chart until you get the chart number you want for it, then delete all the other versions that were created to get there.
Keep in mind, when you duplicate a chart, it is going to use the lowest number available. So if you have charts 3, 4, 6 in your chartbook and you duplicate it, the first one will be chart #1, then chart #2, then chart #5, then Chart #7.
