Date/Time: Wed, 25 Nov 2026 16:39:18 +0000
"Symbol" and "Trade and current quote symbol question"
View Count: 406
[2025-10-23 17:31:00]
ldepadey - Posts: 73
Hi there, I am looking to execute trades on FDXM with using analysis and levels from FDAX.
I have changed the trade and current quote symbol to FDXM and remained the symbol on FDAX.
However, I am unsure what to put in the symbol settings so the ticks and tick sizes match up?
please find screenshot attached
imageScreenshot 2025-10-23 182557.png / V - Attached On 2025-10-23 17:30:50 UTC - Size: 83.45 KB - 188 views
[2025-10-23 19:19:24]
The Tick Size for FDAX and FDXM are both 1.0, so there is nothing you should need to change with regards to the Tick Size.
The only item you would need to update is the "Currency Value Per Tick" to set it to the value for FDXM, which is 5.0. Refer to the following:
Chart Settings: Updating Currency Value per Tick for Trade Symbol
