Date/Time: Wed, 25 Nov 2026 16:39:25 +0000
Attached Order
View Count: 388
| [2025-10-23 14:41:24] |
| User929560 - Posts: 1 |
Good morning, Is it possible to configure the platform so that the attahced stop loss automatically adjusts the quantity after a non-attached limit order is triggered? Example shown in the image. Exemple, after selling four contracts, if the TP is triggered, does the SL automatically adjust the quantity? I really need the take profit to be placed before the entry order is triggered. Thanks |
Attachment Deleted. |
| [2025-10-23 17:29:44] |
| rajeshh - Posts: 50 |
It looks like you are placing the stop order as an attached order, but the take profit order as a non-attached order? You can still enter the take profit order as an attached order when entering the entry order, before the entry order is triggered. If you are placing additional (entry) orders after the initial entry order has been placed, and want them to add to the existing attached orders, make sure the Support Scale in option in the M menu of the Trade Window is checked. Hopefully, I understood your problem correctly. |
