Date/Time: Wed, 25 Nov 2026 16:39:25 +0000
Missing Qoutes
View Count: 394
[2025-10-22 15:02:44]
User664240 - Posts: 209
Several Symbols are not populating
imageScreenshot 2025-10-22 105938.png / V - Attached On 2025-10-22 15:01:50 UTC - Size: 29.57 KB - 190 views
[2025-10-23 06:11:48]
Sierra_Chart Engineering - Posts: 25481
Do you know how many symbols you are tracking? Refer to:
Chart Data and Chart Data Files: Reducing Number of Symbols Being Tracked by Sierra Chart
[2025-10-23 21:56:01]
IN that instance 830, across all instances about 2k. That spreadsheet did eventually populate though.
[2025-10-24 21:21:46]
The limit of 2000 symbols on the server side for the stock data, most likely has been gone over.
