Date/Time: Wed, 25 Nov 2026 16:39:26 +0000
Fast Persistent Variables
View Count: 747
[2025-10-22 13:47:56]
skalaydzhiyski - Posts: 139
Hi SC,
I just wanted some more clarity on how the *Fast persistent variable functions are faster than the normal ones, and why would one prefer one over another. Is there a rule of thumb / best practice ?
Any implementation details are also welcome.
All the best,
[2025-10-22 14:41:50]
Sierra_Chart Engineering - Posts: 25481
The fast persistent variable functions, store data in STL vector as compared to an STL map and a vector is always going to be faster when there are a large number of elements.
With a vector, referencing the variable is always done as an offset to a memory address rather than having to perform a search to find the element.
Although thinking about it, will be able to speed up the STL map by using a hash map. We will look into that. In which case the hash map would be nearly as fast as a vector.
Date Time Of Last Edit: 2025-10-22 14:42:47
[2025-10-22 15:57:41]
Alright, this makes perfect sense, but what I don't get is why do we have a map as implementation for persistent variables in the first place when the indices (the keys of the map) are always integers ? I guess if we have 1000s of persistent variables for a study the map search will be faster, than the vector search.
But I guess it's always better to have std::vector<int>* as persistent pointer rather than std::vector<persistent ints> if you wanted a large number of variables.
Anyway just thinking out loud, thanks for the quick response!
All the best,
Date Time Of Last Edit: 2025-10-22 16:01:53
[2025-10-24 18:43:54]
The map is used because the integers can be any value. If you use a value of 1000000, it would make a vector, 1 million elements and using a huge amount of memory. The memory allocation could also likely fail.
No, it will be the opposite:
We do not understand this:
Date Time Of Last Edit: 2025-10-24 18:44:28
