Date/Time: Wed, 25 Nov 2026 16:39:24 +0000
Create a long term chart showing only 70% of the voluma area daily
View Count: 465
| [2025-10-22 09:21:25] |
| User751630 - Posts: 28 |
Hello! I want to know if we can show a chart with: -on vertical axis = price -on horizontal axis = 70% of one day range with the most volume(which form a rectangle in the chart, 1 day= 1 rectangle) It's to identify longer term value area see the screenshot attached. Thanks |
| [2025-10-22 14:16:54] |
| maxima120 - Posts: 177 |
you probably want a custom chart ACSIL code - you can draw day bars any way you need from it. its not as hard as it sounds
| [2025-10-22 18:21:39] |
You can use the "Volume Value Area Lines" to get the bounds of the value area you want over a period of time. You can do this for multiple days and then extend them forward so you can see them together in one area of a chart. Refer to the following: Volume Value Area Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-23 05:25:46] |
Ok thanks to you all i will check that.
