Date/Time: Wed, 25 Nov 2026 16:24:52 +0000
ICT STDV Retracement Tool Not Scaling Correctly — Levels Compressed Near One Price
View Count: 463
[2025-10-21 08:00:32]
Almoomoo - Posts: 1
I’m having an issue setting up the Price Retracement tool for my ICT STDV (Standard Deviation projection) setup. No matter what direction I draw it (high to low or low to high), all of the levels appear compressed near a single price area instead of scaling proportionally across the range.
Here’s what I’ve already tried
Rebuilt the retracement config from scratch
Toggled Reverse Percentages
Enabled First Point Always 100 Percent
Set the chart scale to Automatic
Tested on new chartbooks and chart regions
The issue persists even after resetting and reloading chart data. Could you please confirm if there’s a known configuration issue or provide a reset/fix for the retracement tool so it correctly displays STDV fib levels
Some help would be great 😊
[2025-10-21 14:27:16]
Please give us an image of the entire chart that includes what you are seeing by following these instructions:
