Date/Time: Wed, 25 Nov 2026 16:24:53 +0000
distance to the top
View Count: 341
| [2025-10-20 07:00:24] |
| nicktrader - Posts: 817 |
As far as I know, there is the option to adjust the distance to the top and bottom edges of a chart. I can't find it... Many thanks |
| [2025-10-20 12:23:28] |
Just found ==>> Scale Settings
| [2025-10-20 16:25:28] |
We think you are looking for this: Chart Scale and Scale Adjusting: Default Scale Padding Percentage (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
