Date/Time: Wed, 25 Nov 2026 16:24:50 +0000
Two AMP account or sub-accounts under on Sierra Login
View Count: 540
[2025-10-18 08:05:39]
User173763 - Posts: 14
Hi support,
I have Denali 12 package. I am using AMP with Teton. I want to have a different account when trading ETH or RTH. Separation of statistics and fund allocation.
What is the best way to do that ? Setup a second account in AMP , only create a sub-account ? How i can connect them to my Sierra Chart login and choose respectively which account i will be trading with?
Thanks in Advance
[2025-10-19 06:29:52]
Sierra_Chart Engineering - Posts: 25481
Have AMP set up another account on Teton order routing and assign it to your same Sierra Chart username. You will then be able to access this second account in your installation of Sierra Chart connected to Teton order routing.
It does not have to be a subaccount. It only needs to be a subaccount if you want to share the same account balance with it as the main account.
Date Time Of Last Edit: 2025-10-19 06:31:14
