Date/Time: Wed, 25 Nov 2026 16:24:52 +0000
Replay slows progressively the longer I run it
View Count: 1011
| [2025-10-17 14:29:52] |
| User98657 - Posts: 420 |
I'm running extended periods of replay (a year) and experiencing a progressive slowing of replay speed. I'm not at all suggesting this is a Sierr Chart fault, cause, or issue. I'm just asking for suggestions, or ideas. I'm running replay with an ACSIL Custom Study for long-ish periods (as I said, a year) on tick data and Renko bars. I'm running this on a separate instance of SC. I'm setting the chart to use specific dates, and condensing my evening session time to only include the 15 minutes prior to the start of the US RTH open at 9:30e. "Skip Empty Periods" is enabled on replay. I'm using Accurate Trading System Back Test Mode for consistency. I run these tests Disconnected from the data feed. I've read as much documentationn and help/trouble tickets as I can find related to the issue, and combed through all the suggested chart settings to help replay run efficiently, such as Update Intervals. When I start the back test, things run fine. There's a noticeable difference between speed selections, and I can see a fairly smooth data feed until I start pushing above 240x, which is when I begin to see that start-stop / "data gathering" pause, data dump on to the screen, pause while it gathers more data...... I don't particularly care for the start, pause, dump, but I understand it, and the testing has been VERY consistent (amazingly consistent). I generally run it at 960x. Beyond 960, there's no noticeable difference in actual speed. HOWEVER, It seems to run the first few months of data consistently, then begins to slow. And it continues to slow the longer it runs. Last night, it only processed two months of data in the 7 hours I was sleeping. This is obviously painfully slow, and not at all what I see when I begin the run. I'm running an I9-13900 with 32GB of Ram and SC is housed on a 2TB SSD. I'm using two Nvidia 8GB Display Adapters for 5 24" monitors, but not using Open GL due to the driver conflicts we began experiencing with Open GL. I realize there are many factors you can't speak to. I realize you can't know how many ticks are being processed on any given day and busy days will be very data intensive. But this isn't slowing down for one, two, or even a few days. It's slowing down overall. I'm not using very many studies on the chart, and none I would consider to be extremely data intensive other than perhaps the ZigZag study, but I realize you can't possibly know if the Auto-Trading Custom Study I'm using is as efficient as it could possibly be. But again, things seem to start out fine, then become progressively slower. There is of course, no way to accurately quantify any of this, which is as frustrating to me as it must be to you when I can't provide any quantifiable measures. I'm not at all suggesting this is a Sierr Chart fault, cause, or issue. I'm merely reaching out to ask if there's anything you may be aware of that I can change or look at to help avoid this slowing. Is this perhaps a memory caching issue where, due to the nature of how SC data is processed during replay, my machine's memory cache is loading up and leaving less overhead room for data transfer? Though my memory is only loaded to 19GB at the peak of everything running, would I benefit by having 64GB of RAM? Any suggestions would be appreciated, and as always, thanks for the support. |
| [2025-10-17 21:56:47] |
| Sierra_Chart Engineering - Posts: 25481 |
The first thing to do is remove all studies from the chart. To see if studies are the cause of the problem. The fact is though as a chart adds more data, the memory allocations become larger and then it becomes slower working with that memory and reallocating it. This could be quite large allocations that take time to reallocate. Might be best to break up, the testing into multiple periods of time and use multiple charts for each 6-month, for example, block of data. You can control what date range is loaded into each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-10-17 21:57:00
| [2025-10-17 22:05:39] |
Refer to: Auto Trade System Back Testing: Improving Back Test Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
