Date/Time: Wed, 25 Nov 2026 21:45:55 +0000
There is a bug
View Count: 601
| [2025-10-16 20:21:32] |
| User841206 - Posts: 6 |
Hello There is a bug in Sirachart that I wanted to inform you about or if I have the wrong settings, please guide me As you can see in the attached video, when I duplicate the Large Volume Master and change its input, the chart is constantly recalculated and when I remove the same Master, it is fixed. Thanks |
Private File |
| [2025-10-16 20:41:30] |
Hello There is a bug in Sirachart that I wanted to inform you about or if I have the wrong settings, please guide me As you can see in the attached video, when I duplicate the Large Volume study and change its input, the chart is constantly recalculated and when I remove the that study, it is fixed. Thanks |
| [2025-10-16 21:05:21] |
This is not a bug. Refer to sixth paragraph highlighted in beige at the following link: Large Volume Trade Indicator: Description And any time you make a change to the Large Volume Trade Indicator, it will cause the entire chart to recalculate, as the data for the large trades is kept separately, which is also why you can not have more than one instance on a chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-17 19:29:36] |
I understand, thank you. Could you please add a "transparent background - all region" mode in the subgraphs section in the next update, in addition to the "background - all region" ? Thank you very much. |
| [2025-10-17 19:40:25] |
We have noted the request for "Transparent Background - All Regions". We can not say when we would get to any particular request.
| [2025-12-09 05:09:14] |
| Sierra_Chart Engineering - Posts: 25483 |
Regarding post #4 we will try to get to that soon.
