Date/Time: Wed, 25 Nov 2026 16:24:57 +0000
Feature request: grouping of Study Input Settings
View Count: 329
[2025-10-16 12:26:10]
bozo_j - Posts: 51
Hi SC guys,
can you consider adding a possibility to group together various Study input settings under a common named "group", similar to how you are visually grouping them in Global settings, for example?
The reason is that any Study which is even a little bit more complex easily ends up with too many settings to quickly find what you need, thus visual grouping would help with this.
Additionally, ability to search through the list of settings (as there are some Studies right now with enormous list of settings making it very tedious to find them quickly by name) would help; again maybe similar to what you have in Global settings right now, but this is optional.
p.s. While you are at it, there is a function setDescription() on the SC Inputs which does nothing. It would be nice if it was displayed as a help/description text e.g. below where the input field is now, on the bottom of the Study Settings.
Thanks!
Date Time Of Last Edit: 2025-10-16 12:51:31
[2025-10-16 15:32:16]
Eventually the Study Settings window will be replaced with a window similar to the other Settings windows that we have been updating in the system. So this will allow for groupings and searching.
We have noted your Feature Request related to (or in addition to) the SetDescription() function.
