Date/Time: Wed, 25 Nov 2026 16:24:55 +0000
[Programming Help] - Issues with sc.Graphics functions
View Count: 662
[2025-10-15 14:43:21]
User695730 - Posts: 9
I am implementing a sudy with GDIFunction.
It is working fine if I directly use the wingdi interface.
I am on a mac with crossover using sierra 54254.
The code is just to create circles colored based on bid/ask direction for time-and-sales trades:
sc.Graphics.ResetBrush();
sc.Graphics.ResetPen();
int y_coord;
auto x_coord = first_x_coordinate;
int r = 0;
for (auto & trade : *trades)
y_coord = sc.RegionValueToYPixelCoordinate(trade.price, sc.GraphRegion);
auto size = trade.volume >= volume_thresh ? 30 : 6;
auto half_size = size / 2;
switch (trade.type)
case SC_TS_BID:
// SelectObject(DeviceContext, brush_bid);
// SelectObject(DeviceContext, pen_bid)
sc.Graphics.SetBrush(brush_bid);
sc.Graphics.SetPen(pen_bid);
break;
case SC_TS_ASK:
// SelectObject(DeviceContext, brush_ask);
// SelectObject(DeviceContext, pen_ask);
sc.Graphics.SetBrush(brush_ask);
sc.Graphics.SetPen(pen_ask);
break;
if (trade.volume >= volume_thresh)
x_coord -= 12;
// Ellipse(DeviceContext, x_coord - half_size, y_coord - half_size, x_coord + half_size, y_coord + half_size);
sc.Graphics.FillEllipse(x_coord - half_size, y_coord - half_size, x_coord + half_size, y_coord + half_size, trade.type == SC_TS_BID ? brush_bid : brush_ask);
// sc.Graphics.DrawEllipse(x_coord - half_size, y_coord - half_size, x_coord + half_size, y_coord + half_size);
sc.Graphics.DrawTextAt(SCString().Format("%d", trade.volume), x_coord - 0, y_coord - 10);
x_coord -= 12;
x_coord -= 8;
// sc.Graphics.ResetPen();
// sc.Graphics.ResetBrush();
// DeleteObject(brush_bid);
// DeleteObject(brush_ask);
// DeleteObject(pen_bid);
// DeleteObject(pen_ask);
sc.Graphics.ResetTextFont();
sc.Graphics.ResetTextColor();
sc.Graphics.ResetTextAlign();
sc.Graphics.ResetBackgroundMode();
Default study colors are red and green, but the brush never changes color. As can be seen in the screenshot:
https://www.sierrachart.com/image.php?Image=1760538971798.png
The same is true for the "DrawToChart" example in the sierra-chart provided example studies.
https://www.sierrachart.com/image.php?Image=1760539048887.png
From reading the example code, the top-left rectangle should be yellow filled and the other one should be outline only.
Again, with just using wingdi directly, I don't have that problem.
Please advise.
Thanks,
Omer.
[2025-10-15 14:50:10]
User431178 - Posts: 910
You can read about it here - Discrepancies in GDI Drawings Output with OpenGL Enabled/Disabled in Sierra Chart - to my knowledge it is not resolved.
[2025-10-15 14:59:10]
Yes. Thanks for replying. I saw that thread, but I though maybe it's not the same thing since it's a thread from more than a year ago.
Also, the workaround in that thread won't help me, since I need to draw circles, not rectangles.
Additionally, if more users are affected, maybe sierra-chart engineers will decide it's worth their while.
[2025-10-15 15:07:37]
Yes, it's the same thing, when not using OpenGL brush color change only works once.
For me the answer was to use sc.Graphics when OpenGL is enabled and win GDI when not.
[2025-10-15 15:07:55]
Sierra_Chart Engineering - Posts: 25481
For the record, the user in the first post could not be using OpenGL.
Date Time Of Last Edit: 2025-10-15 15:08:26
