Date/Time: Wed, 25 Nov 2026 16:24:50 +0000
vix_cgi
View Count: 568
| [2025-10-15 13:52:49] |
| lservin29 - Posts: 78 |
do i need another package to get faster more accurate VIX_CGI data, i need better intraday data for this CBOE ticker
| [2025-10-15 15:31:22] |
The VIX Index updates every 15 seconds. This is what it is. There is no other option for more/faster data. If this is not what you are asking, then we need more information on what exactly is the question. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-18 11:43:15] |
| user_xyz - Posts: 529 |
Pay for the CFE Top of Book and get access to VX futures (symbol current VXV25-CFE.) This is what you are looking for.
| [2025-10-19 19:12:16] |
| Sierra_Chart Engineering - Posts: 25481 |
The volatility index comes direct from CBOE, and that cash index, is not available any faster. However, there is the CBOE Futures you can use as well as the prior post explains: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedCFE Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
