Date/Time: Tue, 17 Nov 2026 18:09:20 +0000
Spreadsheet System for Trading
View Count: 485
| [2025-10-14 18:37:55] |
| User379029 - Posts: 4 |
The problem is that my trade management is supposed to follow a line from a spreadsheet formula. It works fine in simulation, but in live it’s not working — the line displays, but the management study isn’t following it. ID42.SG1 is the stop-buy line that’s displaying on the chart.The stop should be matching that line, but it isn’t, and I’ve been trying to get it to work.Again, in simulation it works smoothly. |
| [2025-10-14 18:41:20] |
| John - SC Support - Posts: 48555 |
When this occurs get us your Message Log and your Trade Service Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Support Board Posting Information: Providing Lines From Trade Service Log For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-14 19:04:51] |
Bowto is showing nothing, it’s empty
| [2025-10-14 19:08:32] |
Select "Global Settings >> Message Categories" and set everything in there to "Yes". Then get us the logs, they will show the information after you make the above changes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-14 19:58:07] |
2025-10-14 12:38:40.326 | Trade activity files set size: 3337 2025-10-14 12:38:40.332 | Rithmic Direct - DTC | Processed connection points. Count: 452 2025-10-14 12:38:40.358 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2025-10-14 12:38:40.359 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2025-10-14 12:38:40.359 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. 2025-10-14 12:38:40.367 | Reading Internal Order ID file. 2025-10-14 12:38:40.376 | Reading Trade Orders file. 2025-10-14 12:38:40.376 | Reading Trade Positions file. 2025-10-14 12:38:40.376 | Reading Trade Account Data files. 2025-10-14 12:38:40.378 | Software version: 2802 64-bit 2025-10-14 12:38:40.378 | Primary Thread ID: 84980 2025-10-14 12:38:40.378 | Usage end date: 2026-04-17 2025-10-14 12:38:40.378 | Enabled for: Advanced Features 2. 2025-10-14 12:38:40.378 | Enabled for: Sierra Chart Historical Data Service. 2025-10-14 12:38:40.378 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-10-14 12:38:40.378 | Enabled for: Delayed Denali Exchange Data Feed. 2025-10-14 12:38:40.378 | Enabled for exchange2: CME (Trading Account Required) 2025-10-14 12:38:40.378 | Enabled for exchange2: CBOT (Trading Account Required) 2025-10-14 12:38:40.378 | Enabled for exchange2: COMEX (Trading Account Required) 2025-10-14 12:38:40.378 | Enabled for exchange2: NYMEX (Trading Account Required) 2025-10-14 12:38:40.378 | Enabled for exchange2: CFE 2025-10-14 12:38:40.378 | Enabled for exchange2: NASDAQ TotalView US stock data 2025-10-14 12:38:40.378 | Enabled for exchange2: CBOE Global Indexes 2025-10-14 12:38:40.378 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-10-14 12:38:40.378 | Current selected Data/Trading service: Rithmic Direct - DTC 2025-10-14 12:38:40.378 | Custom symbol settings values: enabled 2025-10-14 12:38:40.378 | Chart Update Interval: 500 2025-10-14 12:38:40.378 | Intraday Data Storage Time Unit: 0 2025-10-14 12:38:40.378 | Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) 2025-10-14 12:38:40.378 | 2025-10-14 17:38:40 Local computer time in UTC 2025-10-14 12:38:40.378 | 2025-10-14 12:38:40 Local computer time in SC Time Zone 2025-10-14 12:38:40.378 | 2025-10-14 17:38:37 Server time in UTC 2025-10-14 12:38:40.378 | Local computer UTC time and Server UTC time difference: 2 seconds. 2025-10-14 12:38:40.378 | Program path: C:\SierraChart2\ 2025-10-14 12:38:40.378 | Data Files path: C:\SierraChart2\Data\ 2025-10-14 12:38:40.378 | OS Version Number: 10.0 2025-10-14 12:38:40.378 | Locale Setting: C 2025-10-14 12:38:40.378 | Crash reporter started: true 2025-10-14 12:38:40.378 | 2025-10-14 12:38:40.403 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2025-10-14 12:38:40.432 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2025-10-14 12:38:40.502 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2025-10-14 12:38:40.502 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2025-10-14 12:38:40.666 | Received 5 login tokens. 2025-10-14 12:38:40.967 | Symbol settings MD5 received. Request ID: 1. 2025-10-14 12:38:40.967 | Symbol settings are up-to-date for rithmic_v2.trading. 2025-10-14 12:38:41.006 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | Number times message added: 1 2025-10-14 12:38:41.007 | Rithmic Direct - DTC | Wrote file: C:\SierraChart2\RithmicConnections.json. Size: 105509 2025-10-14 12:38:41.007 | Rithmic Direct - DTC | Processed connection points. Count: 452 2025-10-14 12:38:41.007 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2025-10-14 12:38:41.007 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-10-14 12:38:41.007 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2025-10-14 12:38:42.904 | Requested user files to download. 2025-10-14 12:38:43.290 | File to download: sst_FreeBundle_ARM64.dll. Action: 1 2025-10-14 12:38:43.291 | File to download: sst_FreeBundle_64.dll. Action: 1 2025-10-14 12:38:43.291 | User files to download complete 2025-10-14 12:38:44.897 | 2025-10-14 12:38:44.897 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated 2025-10-14 12:38:44.897 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500 2025-10-14 12:38:44.898 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 2025-10-14 12:38:44.928 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-10-14 12:38:44.929 | DTC Client socket (1) | New receive buffer size: 0 2025-10-14 12:38:44.929 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2025-10-14 12:38:44.990 | Rithmic Direct - DTC | Network connection to server complete. 2025-10-14 12:38:44.990 | Rithmic Direct - DTC | Starting socket receive thread. 2025-10-14 12:38:44.990 | Rithmic Direct - DTC | Using fixed encoding of Binary 2025-10-14 12:38:44.990 | Rithmic Direct - DTC | Sending logon request message. 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | Received logon response. 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | Server Name: . 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | Successfully connected. 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | Trading is supported. 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | Order cancel and replace is supported. 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | OCO Orders supported. 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2025-10-14 12:38:45.246 | Rithmic Direct - DTC | Connection to server complete. 2025-10-14 12:38:45.247 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-10-14 12:38:48.118 | Files to Open on Startup | Opening file: ExampleChartbook.cht 2025-10-14 12:38:48.122 | Chart (XAUUSD) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.122 | Chart (XAUUSD) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.122 | Chart (XAUUSD) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.122 | Chart (XAUUSD) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.133 | XAUUSD 1 Min #1 | Reloading chart. 2025-10-14 12:38:48.134 | Chart (XAUUSD) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.134 | Chart (XAUUSD) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.134 | Chart (XAUUSD) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.134 | Chart (XAUUSD) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.143 | XAUUSD Daily #2 | Reloading chart. 2025-10-14 12:38:48.145 | Chart (YMU25-CBOT) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.145 | Chart (YMU25-CBOT) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.145 | Chart (YMU25-CBOT) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.145 | Chart (YMU25-CBOT) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.157 | YMU25-CBOT 1 Min #3 | Reloading chart. 2025-10-14 12:38:48.158 | Chart (TICK-NYSE) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.158 | Chart (TICK-NYSE) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.158 | Chart (TICK-NYSE) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.158 | Chart (TICK-NYSE) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.171 | TICK-NYSE 1 Min #4 | Reloading chart. 2025-10-14 12:38:48.173 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.173 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.173 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.173 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.185 | MESU25-CME 1 Min #5 | Reloading chart. 2025-10-14 12:38:48.186 | Chart (AMZN-NQTV) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.186 | Chart (AMZN-NQTV) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.186 | Chart (AMZN-NQTV) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.186 | Chart (AMZN-NQTV) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.200 | AMZN-NQTV 60 Min #6 | Reloading chart. 2025-10-14 12:38:48.202 | Chart (EURUSD) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.202 | Chart (EURUSD) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.202 | Chart (EURUSD) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.202 | Chart (EURUSD) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.220 | EURUSD Daily #7 | Reloading chart. 2025-10-14 12:38:48.222 | Chart (EURUSD) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.222 | Chart (EURUSD) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.222 | Chart (EURUSD) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.222 | Chart (EURUSD) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.238 | EURUSD 5 Min #8 | Reloading chart. 2025-10-14 12:38:48.240 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.240 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.240 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.240 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.257 | MESU25-CME #9 | Reloading chart. 2025-10-14 12:38:48.259 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.259 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.259 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.259 | Chart (MESU25-CME) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.629 | MESU25-CME 1 Min #10 | Reloading chart. 2025-10-14 12:38:48.631 | Chart (AAPL) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.631 | Chart (AAPL) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.631 | Chart (AAPL) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.631 | Chart (AAPL) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.652 | AAPL 5 Min #11 | Reloading chart. 2025-10-14 12:38:48.653 | Chart (BTCUSDT_PERP_BINANCE) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.653 | Chart (BTCUSDT_PERP_BINANCE) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.653 | Chart (BTCUSDT_PERP_BINANCE) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.653 | Chart (BTCUSDT_PERP_BINANCE) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.700 | BTCUSDT_PERP_BINANCE 1 Min #12 | Reloading chart. 2025-10-14 12:38:48.702 | Chart (YMU25-CBOT) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 114 2025-10-14 12:38:48.702 | Chart (YMU25-CBOT) | Encountered unknown Chartbook Field. Field Code: 683. Previous Field Code: 683 | Number times message added: 47 2025-10-14 12:38:48.702 | Chart (YMU25-CBOT) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 683 2025-10-14 12:38:48.702 | Chart (YMU25-CBOT) | Encountered unknown Chartbook Field. Field Code: 690. Previous Field Code: 690 | Number times message added: 47 2025-10-14 12:38:48.726 | YMU25-CBOT 10 Min #13 | Reloading chart. 2025-10-14 12:38:48.748 | XAUUSD Daily #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\XAUUSD.dly 2025-10-14 12:38:48.749 | XAUUSD Daily #2 | Chart data loading complete. 2025-10-14 12:38:48.752 | YMU25-CBOT 1 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\YMU25-CBOT.scid 2025-10-14 12:38:48.754 | YMU25-CBOT 1 Min #3 | Chart data loading complete. 2025-10-14 12:38:48.758 | TICK-NYSE 1 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TICK-NYSE.scid 2025-10-14 12:38:48.759 | TICK-NYSE 1 Min #4 | Chart data loading complete. 2025-10-14 12:38:48.763 | MESU25-CME 1 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\MESU25-CME.scid 2025-10-14 12:38:48.764 | MESU25-CME 1 Min #5 | Chart data loading complete. 2025-10-14 12:38:48.768 | AMZN-NQTV 60 Min #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\AMZN-NQTV.scid 2025-10-14 12:38:48.769 | AMZN-NQTV 60 Min #6 | Chart data loading complete. 2025-10-14 12:38:48.776 | EURUSD 5 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\EURUSD.scid 2025-10-14 12:38:48.777 | EURUSD 5 Min #8 | Chart data loading complete. 2025-10-14 12:38:48.785 | EURUSD Daily #7 | Chart data loading complete. 2025-10-14 12:38:48.785 | MESU25-CME #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\MESU25-CME.scid 2025-10-14 12:38:48.786 | MESU25-CME #9 | Chart data loading complete. 2025-10-14 12:38:48.793 | MESU25-CME 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\MESU25-CME.scid 2025-10-14 12:38:48.794 | MESU25-CME 1 Min #10 | Chart data loading complete. 2025-10-14 12:38:48.798 | AAPL 5 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\AAPL.scid 2025-10-14 12:38:48.799 | AAPL 5 Min #11 | Chart data loading complete. 2025-10-14 12:38:48.804 | BTCUSDT_PERP_BINANCE 1 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\BTCUSDT_PERP_BINANCE.scid 2025-10-14 12:38:48.805 | BTCUSDT_PERP_BINANCE 1 Min #12 | Chart data loading complete. 2025-10-14 12:38:48.808 | YMU25-CBOT 10 Min #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\YMU25-CBOT.scid 2025-10-14 12:38:48.809 | YMU25-CBOT 10 Min #13 | Chart data loading complete. 2025-10-14 12:38:48.825 | Starting DelayedDownloadMonitoringTimer 2025-10-14 12:38:48.825 | Starting HDTimeoutTimer 2025-10-14 12:38:48.825 | Added historical Daily data request for XAUUSD to the queue. 2025-10-14 12:38:48.826 | Triggering next historical data download in queue. 2025-10-14 12:38:48.826 | Using Bid/Ask average for last trade price for XAUUSD 2025-10-14 12:38:48.826 | Using symbol data fast lookup vector 2025-10-14 12:38:48.826 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 1 Service code: fxcm 2025-10-14 12:38:48.826 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2025-10-14 12:38:48.826 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 1 2025-10-14 12:38:48.827 | HD Request # 1 | Downloading Historical Daily chart data for XAUUSD. Starting date: 1985-10-24. Service: fxcm 2025-10-14 12:38:48.827 | HD Request # 1 | Using server: ds12.sierracharts.com port 10149 2025-10-14 12:38:48.828 | Added historical Intraday data request for XAUUSD to the queue. 2025-10-14 12:38:48.828 | Intraday data recording state for symbol XAUUSD is set to download 'Pending'. 2025-10-14 12:38:48.828 | Triggering next historical data download in queue. 2025-10-14 12:38:48.829 | Rithmic Direct - DTC | Starting real-time market data updates for: YMU25-CBOT. ID: 2 2025-10-14 12:38:48.829 | Rithmic Direct - DTC | Requesting security definition data for: YMU25-CBOT. ID: 2 2025-10-14 12:38:48.829 | Added historical Intraday data request for YMU25-CBOT to the queue. 2025-10-14 12:38:48.829 | Intraday data recording state for symbol YMU25-CBOT is set to download 'Pending'. 2025-10-14 12:38:48.829 | Triggering next historical data download in queue. 2025-10-14 12:38:48.830 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 3 Service code: statscalc 2025-10-14 12:38:48.830 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 3 2025-10-14 12:38:48.830 | Added historical Intraday data request for TICK-NYSE to the queue. 2025-10-14 12:38:48.830 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2025-10-14 12:38:48.830 | Triggering next historical data download in queue. 2025-10-14 12:38:48.831 | Rithmic Direct - DTC | Starting real-time market data updates for: MESU25-CME. ID: 4 2025-10-14 12:38:48.831 | Rithmic Direct - DTC | Requesting security definition data for: MESU25-CME. ID: 4 2025-10-14 12:38:48.831 | Added historical Intraday data request for MESU25-CME to the queue. 2025-10-14 12:38:48.831 | Intraday data recording state for symbol MESU25-CME is set to download 'Pending'. 2025-10-14 12:38:48.831 | Triggering next historical data download in queue. 2025-10-14 12:38:48.833 | Mapping AMZN-NQTV to AMZN-NQTV. Service code: nasdaq_exchange.data 2025-10-14 12:38:48.833 | Denali Data Feed | Starting real-time market data updates for: AMZN-NQTV (AMZN-NQTV). ID: 5 Service code: nasdaq_exchange.data 2025-10-14 12:38:48.833 | Denali Data Feed | Connecting to the server ds33.sierracharts.com. Port 10045 2025-10-14 12:38:48.833 | Denali Data Feed | Requesting security definition data for: AMZN-NQTV (AMZN-NQTV). ID: 5 2025-10-14 12:38:48.833 | Added historical Intraday data request for AMZN-NQTV to the queue. 2025-10-14 12:38:48.833 | Intraday data recording state for symbol AMZN-NQTV is set to download 'Pending'. 2025-10-14 12:38:48.833 | Triggering next historical data download in queue. 2025-10-14 12:38:48.836 | Using Bid/Ask average for last trade price for EURUSD 2025-10-14 12:38:48.836 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 6 Service code: fxcm 2025-10-14 12:38:48.836 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 6 2025-10-14 12:38:48.839 | Added historical Intraday data request for EURUSD to the queue. 2025-10-14 12:38:48.839 | Intraday data recording state for symbol EURUSD is set to download 'Pending'. 2025-10-14 12:38:48.839 | Triggering next historical data download in queue. 2025-10-14 12:38:48.906 | DTC Client socket (2) | Creating socket. 2025-10-14 12:38:48.906 | DTC Client socket (2) | New receive buffer size: 0 2025-10-14 12:38:48.906 | DTC Client socket (2) | Connecting to IP: 69.39.70.241. 2025-10-14 12:38:48.906 | Socket (3) | Creating socket. 2025-10-14 12:38:48.906 | Socket (3) | New receive buffer size: 0 2025-10-14 12:38:48.906 | Socket (3) | Connecting to IP: 69.39.70.241. 2025-10-14 12:38:48.938 | DTC Client socket (4) | Creating socket. 2025-10-14 12:38:48.938 | DTC Client socket (4) | New receive buffer size: 0 2025-10-14 12:38:48.938 | DTC Client socket (4) | Connecting to IP: 69.39.70.245. 2025-10-14 12:38:48.978 | SC Data with Depth | Network connection to server complete. 2025-10-14 12:38:48.978 | SC Data with Depth | Starting socket receive thread. 2025-10-14 12:38:48.978 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2025-10-14 12:38:49.010 | Denali Data Feed | Network connection to server complete. 2025-10-14 12:38:49.010 | Denali Data Feed | Starting socket receive thread. 2025-10-14 12:38:49.010 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2025-10-14 12:38:49.061 | HD Request # 1 | Setting DTC encoding to Binary VLS 2025-10-14 12:38:49.061 | HD Request # 1 | Sending historical data logon request message. 2025-10-14 12:38:49.078 | SC Data with Depth | Setting DTC encoding to Binary VLS 2025-10-14 12:38:49.078 | SC Data with Depth | Sending logon request message. 2025-10-14 12:38:49.099 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-10-14 12:38:49.099 | Denali Data Feed | Sending logon request message. 2025-10-14 12:38:49.151 | Mapping AAPL to AAPL. Service code: us_equities_utp_cta_exchange.data 2025-10-14 12:38:49.151 | Delayed Data Feed | Starting real-time market data updates for: AAPL (AAPL). ID: 7 Service code: us_equities_utp_cta_exchange.data 2025-10-14 12:38:49.152 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2025-10-14 12:38:49.152 | Delayed Data Feed | Requesting security definition data for: AAPL (AAPL). ID: 7 2025-10-14 12:38:49.152 | Added historical Intraday data request for AAPL to the queue. 2025-10-14 12:38:49.152 | Intraday data recording state for symbol AAPL is set to download 'Pending'. 2025-10-14 12:38:49.152 | Triggering next historical data download in queue. 2025-10-14 12:38:49.159 | HD Request # 1 | Requesting historical Daily data starting at 1985-10-24. 2025-10-14 12:38:49.190 | DTC Client socket (5) | Creating socket. 2025-10-14 12:38:49.190 | DTC Client socket (5) | New receive buffer size: 0 2025-10-14 12:38:49.190 | DTC Client socket (5) | Connecting to IP: 67.214.125.11. 2025-10-14 12:38:49.220 | HD Request # 1 | Decompressing data. 2025-10-14 12:38:49.309 | Loading DLL: C:\SierraChart2\Data\ETOFSv3.dll (ETOFSv3_64.dll). Handle: 7ffcc02a0000 2025-10-14 12:38:49.371 | ESZ5.CME/MES?#.CME 30 Min #1 | Reloading chart. 2025-10-14 12:38:49.487 | HD Request # 1 | Receiving historical Daily data for XAUUSD starting at 1985-10-25. 2025-10-14 12:38:49.487 | HD Request # 1 | Writing historical Daily data to the file XAUUSD.dly. 2025-10-14 12:38:49.558 | Socket (3) | CloseSocket call. 2025-10-14 12:38:49.558 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-10-14 12:38:49.623 | Socket (3) | Socket gracefully closed by remote side. 2025-10-14 12:38:49.623 | Socket (3) | Closed. 2025-10-14 12:38:49.758 | ESZ5.CME/MESZ5.CME 15 Sec #2 | Reloading chart. 2025-10-14 12:38:49.763 | Delayed Data Feed | Network connection to server complete. 2025-10-14 12:38:49.763 | Delayed Data Feed | Starting socket receive thread. 2025-10-14 12:38:49.763 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-10-14 12:38:49.769 | XAUUSD[M] 1 Min #1 | Chart data loading complete. 2025-10-14 12:38:49.773 | Historical data download thread signaled to stop. 2025-10-14 12:38:49.773 | HD Request # 1 | Received 10313 Daily data records from 1985-10-25 00:00:00 to 2025-10-14 00:00:00 (40.0 years) and wrote 10313 records for XAUUSD 2025-10-14 12:38:49.773 | HD Request # 1 | Completion time: 1s. 2025-10-14 12:38:49.773 | HD Request # 1 | Daily data download complete for XAUUSD. Unique request ID: 1 2025-10-14 12:38:49.773 | Removing historical data download ID 1. 2025-10-14 12:38:49.773 | 2025-10-14 12:38:49.773 | Triggering next historical data download in queue. 2025-10-14 12:38:49.774 | SC Data with Depth | Received logon response. 2025-10-14 12:38:49.774 | SC Data with Depth | Server Name: SC Realtime Server. 2025-10-14 12:38:49.774 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2025-10-14 12:38:49.774 | SC Data with Depth | Successfully connected. 2025-10-14 12:38:49.774 | SC Data with Depth | Trading is not supported. 2025-10-14 12:38:49.774 | SC Data with Depth | MarketDepthIsSupported: 1 2025-10-14 12:38:49.774 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD 2025-10-14 12:38:49.774 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2025-10-14 12:38:49.774 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD 2025-10-14 12:38:49.774 | Denali Data Feed | Received logon response. 2025-10-14 12:38:49.774 | Denali Data Feed | Server Name: SC Realtime Server. 2025-10-14 12:38:49.774 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-10-14 12:38:49.775 | Denali Data Feed | Successfully connected. 2025-10-14 12:38:49.775 | Denali Data Feed | Trading is not supported. 2025-10-14 12:38:49.775 | Denali Data Feed | MarketDepthIsSupported: 1 2025-10-14 12:38:49.775 | Denali Data Feed | Restarting real-time data updates for symbol: AMZN-NQTV -> AMZN-NQTV 2025-10-14 12:38:49.775 | Delaying start of download for XAUUSD. 2025-10-14 12:38:49.820 | Rithmic Direct - DTC | Starting real-time market data updates for: BTCUSDT_PERP_BINANCE. ID: 8 2025-10-14 12:38:49.820 | Rithmic Direct - DTC | Requesting security definition data for: BTCUSDT_PERP_BINANCE. ID: 8 2025-10-14 12:38:49.820 | Added historical Intraday data request for BTCUSDT_PERP_BINANCE to the queue. 2025-10-14 12:38:49.820 | Intraday data recording state for symbol BTCUSDT_PERP_BINANCE is set to download 'Pending'. 2025-10-14 12:38:49.820 | Triggering next historical data download in queue. 2025-10-14 12:38:49.822 | XAUUSD[M] Daily #2 | Reloading chart. 2025-10-14 12:38:49.835 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2025-10-14 12:38:49.835 | Delayed Data Feed | Sending logon request message. 2025-10-14 12:38:49.859 | XAUUSD[M] Daily #2 | Chart data loading complete. 2025-10-14 12:38:49.863 | Mapping ESZ5.CME to ESZ25. Service code: cme 2025-10-14 12:38:49.863 | Denali Data Feed | Starting real-time market data updates for: ESZ5.CME (ESZ25). ID: 9 Service code: cme 2025-10-14 12:38:49.864 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 443 2025-10-14 12:38:49.864 | Denali Data Feed | Requesting security definition data for: ESZ5.CME (ESZ25). ID: 9 2025-10-14 12:38:49.864 | Rithmic Direct - DTC | Starting real-time market data updates for: MES?#.CME. ID: 10 2025-10-14 12:38:49.864 | Rithmic Direct - DTC | Requesting security definition data for: MES?#.CME. ID: 10 2025-10-14 12:38:49.865 | Added historical Intraday data request for ESZ5.CME to the queue. 2025-10-14 12:38:49.865 | Intraday data recording state for symbol ESZ5.CME is set to download 'Pending'. 2025-10-14 12:38:49.865 | Triggering next historical data download in queue. 2025-10-14 12:38:49.888 | DTC Client socket (3) | Creating socket. 2025-10-14 12:38:49.888 | DTC Client socket (3) | New receive buffer size: 0 2025-10-14 12:38:49.888 | DTC Client socket (3) | Connecting to IP: 216.200.108.154. 2025-10-14 12:38:49.926 | SC Data with Depth | Setting external service identifier for symbol EURUSD to 18 2025-10-14 12:38:49.926 | SC Data with Depth | Received security definition for symbol EURUSD 2025-10-14 12:38:49.926 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2025-10-14 12:38:49.926 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2025-10-14 12:38:49.926 | SC Data with Depth | Setting external service identifier for symbol XAUUSD to 62 2025-10-14 12:38:49.926 | SC Data with Depth | Received security definition for symbol XAUUSD 2025-10-14 12:38:49.943 | Denali Data Feed | Setting external service identifier for symbol AMZN-NQTV to 509 2025-10-14 12:38:49.943 | Denali Data Feed | Received security definition for symbol AMZN-NQTV 2025-10-14 12:38:49.945 | Denali Data Feed | Network connection to server complete. 2025-10-14 12:38:49.945 | Denali Data Feed | Starting socket receive thread. 2025-10-14 12:38:49.945 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-10-14 12:38:49.990 | Delayed Data Feed | Received logon response. 2025-10-14 12:38:49.990 | Delayed Data Feed | Server Name: SC Realtime Server. 2025-10-14 12:38:49.990 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2025-10-14 12:38:49.990 | Delayed Data Feed | Successfully connected. 2025-10-14 12:38:49.990 | Delayed Data Feed | Trading is not supported. 2025-10-14 12:38:49.990 | Delayed Data Feed | MarketDepthIsSupported: 1 2025-10-14 12:38:49.990 | Delayed Data Feed | Restarting real-time data updates for symbol: AAPL -> AAPL 2025-10-14 12:38:50.022 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-10-14 12:38:50.022 | Denali Data Feed | Sending logon request message. 2025-10-14 12:38:50.151 | Delayed Data Feed | Setting external service identifier for symbol AAPL to 22 2025-10-14 12:38:50.151 | Delayed Data Feed | Received security definition for symbol AAPL 2025-10-14 12:38:50.246 | Requesting market depth updates for: ESZ5.CME if supported. NumLevels=100 2025-10-14 12:38:50.254 | Mapping MESZ5.CME to MESZ25. Service code: cme 2025-10-14 12:38:50.254 | Denali Data Feed | Starting real-time market data updates for: MESZ5.CME (MESZ25). ID: 11 Service code: cme 2025-10-14 12:38:50.254 | Denali Data Feed | Requesting security definition data for: MESZ5.CME (MESZ25). ID: 11 2025-10-14 12:38:50.620 | Denali Data Feed | Received logon response. 2025-10-14 12:38:50.620 | Denali Data Feed | Server Name: SC Realtime Server. 2025-10-14 12:38:50.620 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-10-14 12:38:50.620 | Denali Data Feed | Successfully connected. 2025-10-14 12:38:50.620 | Denali Data Feed | Trading is not supported. 2025-10-14 12:38:50.620 | Denali Data Feed | MarketDepthIsSupported: 1 2025-10-14 12:38:50.620 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ5.CME -> ESZ25. Market Depth data restarted. 2025-10-14 12:38:50.620 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ5.CME -> MESZ25 2025-10-14 12:38:50.706 | Added historical Daily data request for EURUSD to the queue. 2025-10-14 12:38:50.706 | Triggering next historical data download in queue. 2025-10-14 12:38:50.832 | Denali Data Feed | Clearing market depth for ESZ5.CME 2025-10-14 12:38:50.832 | Denali Data Feed | Setting external service identifier for symbol ESZ5.CME to 294973 2025-10-14 12:38:50.833 | Denali Data Feed | Received security definition for symbol ESZ5.CME 2025-10-14 12:38:50.833 | Denali Data Feed | Setting external service identifier for symbol MESZ5.CME to 42004164 2025-10-14 12:38:50.833 | Denali Data Feed | Received security definition for symbol MESZ5.CME 2025-10-14 12:38:51.815 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | StartDateTimeForLoadingOrderFills: 2025-10-13 17:00:00 2025-10-14 12:38:52.817 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Chart data loading complete. 2025-10-14 12:38:53.521 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-10-07 00:00:00 2025-10-14 12:38:53.530 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 12:38:53.576 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:38:53.576 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Chart data loading complete. 2025-10-14 12:38:53.586 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. | Number times message added: 1 2025-10-14 12:38:53.738 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:38:54.478 | HD Request # 2 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm 2025-10-14 12:38:54.478 | HD Request # 2 | Download start date-time: 2025-09-12 03:20:58.000000. File last date-time: 2025-09-12 03:20:58.777000 2025-10-14 12:38:54.478 | HD Request # 2 | Using server: ds4.sierracharts.com port 10150 2025-10-14 12:38:54.510 | Socket (9) | Creating socket. 2025-10-14 12:38:54.510 | Socket (9) | New receive buffer size: 0 2025-10-14 12:38:54.510 | Socket (9) | Connecting to IP: 64.152.155.113. 2025-10-14 12:38:54.640 | HD Request # 2 | Setting DTC encoding to Binary VLS 2025-10-14 12:38:54.640 | HD Request # 2 | Sending historical data logon request message. 2025-10-14 12:38:54.748 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-09-12 03:20:58. Record interval: 0. Symbol: XAUUSD 2025-10-14 12:38:54.808 | HD Request # 2 | Decompressing data. 2025-10-14 12:38:54.986 | HD Request # 2 | Receiving Intraday data for XAUUSD starting at 2025-09-12 03:20:58.188000 2025-10-14 12:38:55.195 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-09-12 03:20:58.788000. 2025-10-14 12:39:04.904 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Creating socket. Using TLS 1.2. 2025-10-14 12:39:04.904 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | New receive buffer size: 0 2025-10-14 12:39:04.904 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Connecting to IP: 38.79.0.89. 2025-10-14 12:39:06.040 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Socket gracefully closed by remote side. 2025-10-14 12:39:06.040 | Rithmic Direct - DTC | Wrote file: C:\SierraChart2\RithmicConnections.json. Size: 105509 2025-10-14 12:39:06.040 | Rithmic Direct - DTC | Processed connection points. Count: 452 2025-10-14 12:39:06.041 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | CloseSocket call. 2025-10-14 12:39:06.041 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-10-14 12:39:06.041 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Closed. 2025-10-14 12:40:08.220 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2025-10-14 12:40:08.221 | DTC Client socket (1) | CloseSocket call. 2025-10-14 12:40:08.221 | DTC Client socket (1) | Max send buffers used during socket life: 3 2025-10-14 12:40:08.221 | DTC Client socket (1) | Max send buffer size during socket life: 651 2025-10-14 12:40:08.221 | Denali Data Feed | Waiting for socket receive thread to end 2025-10-14 12:40:08.221 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:08.221 | DTC Client socket (3) | CloseSocket call. 2025-10-14 12:40:08.221 | Denali Data Feed | Disconnected from the server. 2025-10-14 12:40:08.221 | Denali Data Feed | Waiting for socket receive thread to end 2025-10-14 12:40:08.222 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:08.222 | DTC Client socket (4) | CloseSocket call. 2025-10-14 12:40:08.222 | Denali Data Feed | Disconnected from the server. 2025-10-14 12:40:08.222 | SC Data with Depth | Waiting for socket receive thread to end 2025-10-14 12:40:08.222 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:08.222 | DTC Client socket (2) | CloseSocket call. 2025-10-14 12:40:08.222 | SC Data with Depth | Disconnected from the server. 2025-10-14 12:40:08.222 | Delayed Data Feed | Waiting for socket receive thread to end 2025-10-14 12:40:08.222 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:08.223 | DTC Client socket (5) | CloseSocket call. 2025-10-14 12:40:08.223 | Delayed Data Feed | Disconnected from the server. 2025-10-14 12:40:08.223 | Rithmic Direct - DTC | Disconnected. 2025-10-14 12:40:08.223 | Canceling queued historical data download request for YMU25-CBOT Intraday data. 2025-10-14 12:40:08.223 | Removing historical data download ID 3. 2025-10-14 12:40:08.223 | Canceling queued historical data download request for TICK-NYSE Intraday data. 2025-10-14 12:40:08.223 | Removing historical data download ID 4. 2025-10-14 12:40:08.223 | Real-time Intraday chart data file updates started for TICK-NYSE 2025-10-14 12:40:08.223 | DTC Client socket (5) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:08.223 | Intraday chart data file opened for TICK-NYSE 2025-10-14 12:40:08.223 | Canceling queued historical data download request for MESU25-CME Intraday data. 2025-10-14 12:40:08.223 | Removing historical data download ID 5. 2025-10-14 12:40:08.223 | Canceling queued historical data download request for AMZN-NQTV Intraday data. 2025-10-14 12:40:08.223 | Removing historical data download ID 6. 2025-10-14 12:40:08.223 | Real-time Intraday chart data file updates started for AMZN-NQTV 2025-10-14 12:40:08.223 | Intraday chart data file opened for AMZN-NQTV 2025-10-14 12:40:08.223 | Canceling queued historical data download request for EURUSD Intraday data. 2025-10-14 12:40:08.223 | Removing historical data download ID 7. 2025-10-14 12:40:08.223 | Real-time Intraday chart data file updates started for EURUSD 2025-10-14 12:40:08.223 | Intraday chart data file opened for EURUSD 2025-10-14 12:40:08.223 | Canceling queued historical data download request for AAPL Intraday data. 2025-10-14 12:40:08.223 | Removing historical data download ID 8. 2025-10-14 12:40:08.223 | Real-time Intraday chart data file updates started for AAPL 2025-10-14 12:40:08.223 | Intraday chart data file opened for AAPL 2025-10-14 12:40:08.223 | Canceling queued historical data download request for BTCUSDT_PERP_BINANCE Intraday data. 2025-10-14 12:40:08.223 | Removing historical data download ID 9. 2025-10-14 12:40:08.223 | Canceling queued historical data download request for ESZ5.CME Intraday data. 2025-10-14 12:40:08.223 | Removing historical data download ID 10. 2025-10-14 12:40:08.223 | Real-time Intraday chart data file updates started for ESZ5.CME 2025-10-14 12:40:08.223 | Intraday chart data file opened for ESZ5.CME 2025-10-14 12:40:08.223 | Canceling queued historical data download request for EURUSD Daily data. 2025-10-14 12:40:08.223 | Removing historical data download ID 11. 2025-10-14 12:40:08.223 | HD Request # 2 | Active download canceled. 2025-10-14 12:40:08.223 | Historical data download thread signaled to stop. 2025-10-14 12:40:08.223 | Socket (9) | CloseSocket call. 2025-10-14 12:40:08.223 | Socket (9) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:08.225 | HD Request # 2 | Received 15635704 Intraday data records from 2025-09-12 03:20:58.188000 to 2025-10-10 07:56:05.405000 (28.2 days. Delay: 4.2 days) and wrote 15635698 records for XAUUSD 2025-10-14 12:40:08.225 | HD Request # 2 | Completion time: 1m 14s. 2025-10-14 12:40:08.225 | HD Request # 2 | Intraday data download complete for XAUUSD. Unique request ID: 2 2025-10-14 12:40:08.225 | Removing historical data download ID 2. 2025-10-14 12:40:08.225 | Real-time Intraday chart data file updates started for XAUUSD 2025-10-14 12:40:08.225 | Intraday chart data file opened for XAUUSD 2025-10-14 12:40:08.225 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2025-10-14 12:40:08.225 | 2025-10-14 12:40:08.225 | No download requests in the queue to start downloads for. 2025-10-14 12:40:08.253 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 2. 2025-10-14 12:40:08.253 | Current selected Data/Trading service: SC Data 2025-10-14 12:40:08.288 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-10-14 12:40:08.288 | DTC Client socket (1) | Closed. 2025-10-14 12:40:08.295 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-10-14 12:40:08.295 | DTC Client socket (4) | Closed. 2025-10-14 12:40:08.301 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-10-14 12:40:08.301 | DTC Client socket (2) | Closed. 2025-10-14 12:40:08.337 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-10-14 12:40:08.337 | DTC Client socket (3) | Closed. 2025-10-14 12:40:08.395 | DTC Client socket (5) | Socket gracefully closed by remote side. 2025-10-14 12:40:08.395 | DTC Client socket (5) | Closed. 2025-10-14 12:40:08.618 | Socket (9) | Socket gracefully closed by remote side. 2025-10-14 12:40:08.618 | Socket (9) | Closed. 2025-10-14 12:40:09.058 | Symbol settings MD5 received. Request ID: 2. 2025-10-14 12:40:09.058 | Requested symbol settings for service code scdataallservices. Request ID: 3. 2025-10-14 12:40:09.405 | SC Data | Disconnected. | Number times message added: 1 2025-10-14 12:40:09.406 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-10-14 12:40:09.760 | ESZ25-CME/MESZ25-CME[M] 15 Sec #2 | Reloading chart. 2025-10-14 12:40:09.865 | ESZ25-CME/MES?#.CME[M] 30 Min #1 | Reloading chart. 2025-10-14 12:40:10.101 | Symbol settings received. Request ID: 3. 2025-10-14 12:40:10.256 | Mapping ESZ25-CME to ESZ25. Service code: cme 2025-10-14 12:40:10.256 | Mapping MESZ25-CME to MESZ25. Service code: cme 2025-10-14 12:40:10.256 | Added historical Intraday data request for ESZ25-CME to the queue. 2025-10-14 12:40:10.256 | Intraday data recording state for symbol ESZ25-CME is set to download 'Pending'. 2025-10-14 12:40:10.256 | Triggering next historical data download in queue. 2025-10-14 12:40:10.256 | HD Request # 3 | Downloading Intraday chart data for ESZ25-CME to the file ESZ25-CME.scid. Service: cme 2025-10-14 12:40:10.266 | HD Request # 3 | Download start date-time: 2025-10-14 08:51:45.000000. File last date-time: 2025-10-14 08:51:45.891000 2025-10-14 12:40:10.266 | HD Request # 3 | Using server: ds28.sierracharts.com port 10149 2025-10-14 12:40:10.296 | Socket (2) | Creating socket. 2025-10-14 12:40:10.296 | Socket (2) | New receive buffer size: 0 2025-10-14 12:40:10.296 | Socket (2) | Connecting to IP: 67.214.125.5. 2025-10-14 12:40:10.458 | HD Request # 3 | Setting DTC encoding to Binary VLS 2025-10-14 12:40:10.458 | HD Request # 3 | Sending historical data logon request message. 2025-10-14 12:40:10.570 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-10-14 08:51:45. Record interval: 0. Symbol: ESZ25 2025-10-14 12:40:10.639 | HD Request # 3 | Decompressing data. 2025-10-14 12:40:10.739 | HD Request # 3 | Receiving Intraday data for ESZ25-CME starting at 2025-10-14 08:51:45.017000 2025-10-14 12:40:10.980 | HD Request # 3 | Timestamp of first Intraday data file record written: 2025-10-14 08:51:45.946000. 2025-10-14 12:40:11.399 | 2025-10-14 12:40:11.400 | SC Data | Connection to server complete. 2025-10-14 12:40:11.400 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-10-14 12:40:11.889 | Mapping ESZ25-CME to ESZ25. Service code: cme 2025-10-14 12:40:11.889 | Using symbol data fast lookup vector 2025-10-14 12:40:11.889 | Denali Data Feed | Starting real-time market data updates for: ESZ25-CME (ESZ25). ID: 1 Service code: cme 2025-10-14 12:40:11.889 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10048 2025-10-14 12:40:11.889 | Denali Data Feed | Requesting security definition data for: ESZ25-CME (ESZ25). ID: 1 2025-10-14 12:40:11.889 | Mapping MESZ25-CME to MESZ25. Service code: cme 2025-10-14 12:40:11.889 | Denali Data Feed | Starting real-time market data updates for: MESZ25-CME (MESZ25). ID: 2 Service code: cme 2025-10-14 12:40:11.889 | Denali Data Feed | Requesting security definition data for: MESZ25-CME (MESZ25). ID: 2 2025-10-14 12:40:11.890 | SC Data | Starting real-time market data updates for: MES?#.CME. ID: 3 2025-10-14 12:40:11.890 | SC Data | Subscribing to streaming market data in the service client is not supported. Symbol: MES?#.CME 2025-10-14 12:40:11.890 | SC Data | Requesting security definition data for: MES?#.CME. ID: 3 2025-10-14 12:40:11.917 | DTC Client socket (1) | Creating socket. 2025-10-14 12:40:11.917 | DTC Client socket (1) | New receive buffer size: 0 2025-10-14 12:40:11.917 | DTC Client socket (1) | Connecting to IP: 64.152.155.18. 2025-10-14 12:40:12.009 | Denali Data Feed | Network connection to server complete. 2025-10-14 12:40:12.009 | Denali Data Feed | Starting socket receive thread. 2025-10-14 12:40:12.009 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-10-14 12:40:12.084 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-10-14 12:40:12.084 | Denali Data Feed | Sending logon request message. 2025-10-14 12:40:12.519 | ESZ25-CME/MESZ25-CME[M] 15 Sec #2 | StartDateTimeForLoadingOrderFills: 2025-10-13 17:00:00 2025-10-14 12:40:12.680 | Socket (2) | CloseSocket call. 2025-10-14 12:40:12.680 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:12.773 | Socket (2) | Socket gracefully closed by remote side. 2025-10-14 12:40:12.773 | Socket (2) | Closed. 2025-10-14 12:40:13.245 | ESZ25-CME/MESZ25-CME[M] 15 Sec #2 | Chart data loading complete. 2025-10-14 12:40:13.927 | Historical data download thread signaled to stop. 2025-10-14 12:40:13.927 | HD Request # 3 | Received 690112 Intraday data records from 2025-10-14 08:51:45.017000 to 2025-10-14 12:40:11.798002 (3.8 hours. Delay: 2.1 seconds) and wrote 690060 records for ESZ25-CME 2025-10-14 12:40:13.935 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-10-14 17:40:11.798002 2025-10-14 12:40:13.935 | HD Request # 3 | Completion time: 3s. 2025-10-14 12:40:13.935 | HD Request # 3 | Intraday data download complete for ESZ25-CME. Unique request ID: 12 2025-10-14 12:40:13.935 | Removing historical data download ID 12. 2025-10-14 12:40:13.935 | Real-time Intraday chart data file updates started for ESZ25-CME 2025-10-14 12:40:13.935 | Intraday chart data file opened for ESZ25-CME 2025-10-14 12:40:13.935 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2025-10-14 12:40:13.935 | 2025-10-14 12:40:13.935 | No download requests in the queue to start downloads for. 2025-10-14 12:40:13.935 | Historical data for ESZ25-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2025-10-14 12:40:13.937 | Denali Data Feed | Received logon response. 2025-10-14 12:40:13.937 | Denali Data Feed | Server Name: SC Realtime Server. 2025-10-14 12:40:13.937 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-10-14 12:40:13.937 | Denali Data Feed | Successfully connected. 2025-10-14 12:40:13.937 | Denali Data Feed | Trading is not supported. 2025-10-14 12:40:13.937 | Denali Data Feed | MarketDepthIsSupported: 1 2025-10-14 12:40:13.937 | Added historical Intraday data request for ESZ25-CME to the queue. 2025-10-14 12:40:13.937 | Intraday data recording state for symbol ESZ25-CME is set to download 'Pending'. 2025-10-14 12:40:13.937 | Triggering next historical data download in queue. 2025-10-14 12:40:13.937 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ25-CME -> ESZ25 2025-10-14 12:40:13.937 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ25-CME -> MESZ25 2025-10-14 12:40:13.941 | ESZ25-CME/MES?#.CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-10-07 00:00:00 2025-10-14 12:40:13.952 | ESZ25-CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 12:40:13.998 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:40:14.014 | ESZ25-CME/MES?#.CME[M] 30 Min #1 | Chart data loading complete. 2025-10-14 12:40:14.014 | Delaying start of download for ESZ25-CME. 2025-10-14 12:40:14.023 | ESZ25-CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 12:40:14.111 | Denali Data Feed | Setting external service identifier for symbol ESZ25-CME to 294973 2025-10-14 12:40:14.111 | Denali Data Feed | Received security definition for symbol ESZ25-CME 2025-10-14 12:40:14.111 | Denali Data Feed | Setting external service identifier for symbol MESZ25-CME to 42004164 2025-10-14 12:40:14.111 | Denali Data Feed | Received security definition for symbol MESZ25-CME 2025-10-14 12:40:14.120 | ESZ25-CME/MESZ25-CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:40:16.402 | Requesting market depth updates for: ESZ25-CME if supported. NumLevels=100 2025-10-14 12:40:16.583 | Denali Data Feed | Clearing market depth for ESZ25-CME 2025-10-14 12:40:19.822 | HD Request # 4 | Downloading Intraday chart data for ESZ25-CME to the file ESZ25-CME.scid. Service: cme 2025-10-14 12:40:19.822 | HD Request # 4 | Download start date-time: 2025-10-14 12:40:11.000000. File last date-time: 2025-10-14 12:40:11.798002 2025-10-14 12:40:19.822 | HD Request # 4 | Using server: ds26.sierracharts.com port 10150 2025-10-14 12:40:19.855 | Socket (2) | Creating socket. 2025-10-14 12:40:19.855 | Socket (2) | New receive buffer size: 0 2025-10-14 12:40:19.855 | Socket (2) | Connecting to IP: 64.152.155.17. 2025-10-14 12:40:19.990 | HD Request # 4 | Setting DTC encoding to Binary VLS 2025-10-14 12:40:19.990 | HD Request # 4 | Sending historical data logon request message. 2025-10-14 12:40:20.098 | HD Request # 4 | Requesting Intraday data. Start date-time: 2025-10-14 12:40:11. Record interval: 0. Symbol: ESZ25 2025-10-14 12:40:20.164 | HD Request # 4 | Decompressing data. 2025-10-14 12:40:20.229 | HD Request # 4 | Receiving Intraday data for ESZ25-CME starting at 2025-10-14 12:40:11.461000 2025-10-14 12:40:20.229 | Socket (2) | CloseSocket call. 2025-10-14 12:40:20.229 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:20.231 | Historical data download thread signaled to stop. 2025-10-14 12:40:20.231 | HD Request # 4 | Timestamp of first Intraday data file record written: 2025-10-14 12:40:12.190000. 2025-10-14 12:40:20.231 | HD Request # 4 | Received 609 Intraday data records from 2025-10-14 12:40:11.461000 to 2025-10-14 12:40:20.436000 (9.0 seconds. Delay: -0.2 seconds) and wrote 572 records for ESZ25-CME 2025-10-14 12:40:20.241 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2025-10-14 17:40:20.436000 2025-10-14 12:40:20.241 | HD Request # 4 | Completion time: 1s. 2025-10-14 12:40:20.241 | HD Request # 4 | Intraday data download complete for ESZ25-CME. Unique request ID: 13 2025-10-14 12:40:20.241 | Removing historical data download ID 13. 2025-10-14 12:40:20.241 | Real-time Intraday chart data file updates started for ESZ25-CME 2025-10-14 12:40:20.241 | Intraday chart data file opened for ESZ25-CME 2025-10-14 12:40:20.241 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2025-10-14 12:40:20.241 | 2025-10-14 12:40:20.241 | No download requests in the queue to start downloads for. 2025-10-14 12:40:20.298 | Socket (2) | Socket gracefully closed by remote side. 2025-10-14 12:40:20.298 | Socket (2) | Closed. 2025-10-14 12:40:20.372 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:40:20.389 | Opened cached Intraday file: C:\SierraChart2\Data\ESZ25-CME.scid. Thread ID: 26764 2025-10-14 12:40:20.756 | ESZ25-CME/MESZ25-CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:40:25.010 | Denali Data Feed | Waiting for socket receive thread to end 2025-10-14 12:40:25.010 | DTC Client socket (1) | CloseSocket call. 2025-10-14 12:40:25.010 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:25.010 | Denali Data Feed | Disconnected from the server. 2025-10-14 12:40:25.010 | SC Data | Disconnected. | Number times message added: 1 2025-10-14 12:40:25.011 | Rithmic Direct - DTC | Processed connection points. Count: 452 2025-10-14 12:40:25.027 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 4. 2025-10-14 12:40:25.027 | Current selected Data/Trading service: Rithmic Direct - DTC 2025-10-14 12:40:25.056 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. 2025-10-14 12:40:25.056 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | New receive buffer size: 0 2025-10-14 12:40:25.056 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Connecting to IP: 38.79.0.89. 2025-10-14 12:40:25.175 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-10-14 12:40:25.175 | DTC Client socket (1) | Closed. 2025-10-14 12:40:25.748 | Symbol settings MD5 received. Request ID: 4. 2025-10-14 12:40:25.748 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 5. 2025-10-14 12:40:25.900 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | Number times message added: 1 2025-10-14 12:40:25.900 | Rithmic Direct - DTC | Wrote file: C:\SierraChart2\RithmicConnections.json. Size: 105509 2025-10-14 12:40:25.901 | Rithmic Direct - DTC | Processed connection points. Count: 452 2025-10-14 12:40:25.901 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | CloseSocket call. 2025-10-14 12:40:25.901 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-10-14 12:40:25.901 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Closed. 2025-10-14 12:40:26.179 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-10-14 12:40:26.263 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Reloading chart. 2025-10-14 12:40:26.364 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Reloading chart. 2025-10-14 12:40:26.559 | Symbol settings received. Request ID: 5. 2025-10-14 12:40:26.756 | Mapping ESZ5.CME to ESZ25. Service code: cme 2025-10-14 12:40:26.756 | Mapping MESZ5.CME to MESZ25. Service code: cme 2025-10-14 12:40:26.756 | Added historical Intraday data request for ESZ5.CME to the queue. 2025-10-14 12:40:26.756 | Intraday data recording state for symbol ESZ5.CME is set to download 'Pending'. 2025-10-14 12:40:26.756 | Triggering next historical data download in queue. 2025-10-14 12:40:26.756 | HD Request # 5 | Downloading Intraday chart data for ESZ5.CME to the file ESZ5.CME.scid. Service: cme 2025-10-14 12:40:26.757 | HD Request # 5 | Download start date-time: 2025-10-14 12:38:21.000000. File last date-time: 2025-10-14 12:38:21.090000 2025-10-14 12:40:26.757 | HD Request # 5 | Using server: ds32.sierracharts.com port 10149 2025-10-14 12:40:26.785 | Socket (2) | Creating socket. 2025-10-14 12:40:26.785 | Socket (2) | New receive buffer size: 0 2025-10-14 12:40:26.785 | Socket (2) | Connecting to IP: 69.39.70.248. 2025-10-14 12:40:26.947 | HD Request # 5 | Setting DTC encoding to Binary VLS 2025-10-14 12:40:26.947 | HD Request # 5 | Sending historical data logon request message. 2025-10-14 12:40:27.063 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-10-14 12:38:21. Record interval: 0. Symbol: ESZ25 2025-10-14 12:40:27.151 | HD Request # 5 | Decompressing data. 2025-10-14 12:40:27.318 | HD Request # 5 | Receiving Intraday data for ESZ5.CME starting at 2025-10-14 12:38:21.054000 2025-10-14 12:40:27.319 | Socket (2) | CloseSocket call. 2025-10-14 12:40:27.319 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:27.320 | Historical data download thread signaled to stop. 2025-10-14 12:40:27.320 | HD Request # 5 | Timestamp of first Intraday data file record written: 2025-10-14 12:38:21.542000. 2025-10-14 12:40:27.320 | HD Request # 5 | Received 4389 Intraday data records from 2025-10-14 12:38:21.054000 to 2025-10-14 12:40:24.192000 (2.1 minutes. Delay: 3.1 seconds) and wrote 4385 records for ESZ5.CME 2025-10-14 12:40:27.320 | HD Request # 5 | Completion time: 1s. 2025-10-14 12:40:27.320 | HD Request # 5 | Intraday data download complete for ESZ5.CME. Unique request ID: 14 2025-10-14 12:40:27.320 | Removing historical data download ID 14. 2025-10-14 12:40:27.320 | Real-time Intraday chart data file updates started for ESZ5.CME 2025-10-14 12:40:27.320 | Intraday chart data file opened for ESZ5.CME 2025-10-14 12:40:27.320 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2025-10-14 12:40:27.320 | 2025-10-14 12:40:27.320 | No download requests in the queue to start downloads for. 2025-10-14 12:40:27.320 | Historical data for ESZ5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2025-10-14 12:40:27.413 | Socket (2) | Socket gracefully closed by remote side. 2025-10-14 12:40:27.413 | Socket (2) | Closed. 2025-10-14 12:40:28.291 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | StartDateTimeForLoadingOrderFills: 2025-10-13 17:00:00 2025-10-14 12:40:29.024 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Chart data loading complete. 2025-10-14 12:40:29.837 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-10-07 00:00:00 2025-10-14 12:40:29.847 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 12:40:29.892 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:40:29.908 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Chart data loading complete. 2025-10-14 12:40:29.918 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 12:40:30.184 | 2025-10-14 12:40:30.185 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated 2025-10-14 12:40:30.185 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500 2025-10-14 12:40:30.185 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 2025-10-14 12:40:30.219 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2025-10-14 12:40:30.219 | DTC Client socket (3) | New receive buffer size: 0 2025-10-14 12:40:30.219 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2025-10-14 12:40:30.266 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:40:30.976 | Rithmic Direct - DTC | Network connection to server complete. 2025-10-14 12:40:30.976 | Rithmic Direct - DTC | Starting socket receive thread. 2025-10-14 12:40:30.976 | Rithmic Direct - DTC | Using fixed encoding of Binary 2025-10-14 12:40:30.976 | Rithmic Direct - DTC | Sending logon request message. 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | Received logon response. 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | Server Name: . 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | Successfully connected. 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | Trading is supported. 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | Order cancel and replace is supported. 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | OCO Orders supported. 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2025-10-14 12:40:31.211 | Rithmic Direct - DTC | Connection to server complete. 2025-10-14 12:40:31.212 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-10-14 12:40:31.256 | Mapping ESZ5.CME to ESZ25. Service code: cme 2025-10-14 12:40:31.256 | Using symbol data fast lookup vector 2025-10-14 12:40:31.256 | Denali Data Feed | Starting real-time market data updates for: ESZ5.CME (ESZ25). ID: 1 Service code: cme 2025-10-14 12:40:31.256 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2025-10-14 12:40:31.256 | Denali Data Feed | Requesting security definition data for: ESZ5.CME (ESZ25). ID: 1 2025-10-14 12:40:31.256 | Mapping MESZ5.CME to MESZ25. Service code: cme 2025-10-14 12:40:31.256 | Denali Data Feed | Starting real-time market data updates for: MESZ5.CME (MESZ25). ID: 2 Service code: cme 2025-10-14 12:40:31.256 | Denali Data Feed | Requesting security definition data for: MESZ5.CME (MESZ25). ID: 2 2025-10-14 12:40:31.256 | Added historical Intraday data request for ESZ5.CME to the queue. 2025-10-14 12:40:31.256 | Intraday data recording state for symbol ESZ5.CME is set to download 'Pending'. 2025-10-14 12:40:31.256 | Triggering next historical data download in queue. 2025-10-14 12:40:31.272 | Delaying start of download for ESZ5.CME. 2025-10-14 12:40:31.292 | DTC Client socket (1) | Creating socket. 2025-10-14 12:40:31.292 | DTC Client socket (1) | New receive buffer size: 0 2025-10-14 12:40:31.292 | DTC Client socket (1) | Connecting to IP: 67.214.125.6. 2025-10-14 12:40:31.362 | Denali Data Feed | Network connection to server complete. 2025-10-14 12:40:31.362 | Denali Data Feed | Starting socket receive thread. 2025-10-14 12:40:31.362 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-10-14 12:40:31.363 | Rithmic Direct - DTC | Starting real-time market data updates for: MES?#.CME. ID: 3 2025-10-14 12:40:31.363 | Rithmic Direct - DTC | Requesting security definition data for: MES?#.CME. ID: 3 2025-10-14 12:40:31.435 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-10-14 12:40:31.435 | Denali Data Feed | Sending logon request message. 2025-10-14 12:40:31.970 | Denali Data Feed | Received logon response. 2025-10-14 12:40:31.970 | Denali Data Feed | Server Name: SC Realtime Server. 2025-10-14 12:40:31.970 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-10-14 12:40:31.970 | Denali Data Feed | Successfully connected. 2025-10-14 12:40:31.970 | Denali Data Feed | Trading is not supported. 2025-10-14 12:40:31.970 | Denali Data Feed | MarketDepthIsSupported: 1 2025-10-14 12:40:31.970 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ5.CME -> ESZ25 2025-10-14 12:40:31.970 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ5.CME -> MESZ25 2025-10-14 12:40:32.123 | Denali Data Feed | Setting external service identifier for symbol ESZ5.CME to 294973 2025-10-14 12:40:32.123 | Denali Data Feed | Received security definition for symbol ESZ5.CME 2025-10-14 12:40:32.123 | Denali Data Feed | Setting external service identifier for symbol MESZ5.CME to 42004164 2025-10-14 12:40:32.123 | Denali Data Feed | Received security definition for symbol MESZ5.CME 2025-10-14 12:40:36.215 | Requesting market depth updates for: ESZ5.CME if supported. NumLevels=100 2025-10-14 12:40:36.308 | Denali Data Feed | Clearing market depth for ESZ5.CME 2025-10-14 12:40:37.824 | HD Request # 6 | Downloading Intraday chart data for ESZ5.CME to the file ESZ5.CME.scid. Service: cme 2025-10-14 12:40:37.824 | HD Request # 6 | Download start date-time: 2025-10-14 12:40:24.000000. File last date-time: 2025-10-14 12:40:24.192000 2025-10-14 12:40:37.833 | HD Request # 6 | Using server: ds28.sierracharts.com port 10150 2025-10-14 12:40:37.833 | Socket (2) | Creating socket. 2025-10-14 12:40:37.833 | Socket (2) | New receive buffer size: 0 2025-10-14 12:40:37.833 | Socket (2) | Connecting to IP: 67.214.125.5. 2025-10-14 12:40:37.979 | HD Request # 6 | Setting DTC encoding to Binary VLS 2025-10-14 12:40:37.979 | HD Request # 6 | Sending historical data logon request message. 2025-10-14 12:40:38.093 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-10-14 12:40:24. Record interval: 0. Symbol: ESZ25 2025-10-14 12:40:38.157 | HD Request # 6 | Decompressing data. 2025-10-14 12:40:38.235 | HD Request # 6 | Receiving Intraday data for ESZ5.CME starting at 2025-10-14 12:40:24.052000 2025-10-14 12:40:38.235 | Socket (2) | CloseSocket call. 2025-10-14 12:40:38.235 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-10-14 12:40:38.236 | Historical data download thread signaled to stop. 2025-10-14 12:40:38.237 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-10-14 12:40:24.225000. 2025-10-14 12:40:38.237 | HD Request # 6 | Received 885 Intraday data records from 2025-10-14 12:40:24.052000 to 2025-10-14 12:40:35.762000 (11.7 seconds. Delay: 2.5 seconds) and wrote 881 records for ESZ5.CME 2025-10-14 12:40:38.245 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-10-14 17:40:35.762000 2025-10-14 12:40:38.245 | Added 115 Time and Sales records to Intraday data file for ESZ5.CME after download. 2025-10-14 12:40:38.245 | HD Request # 6 | Completion time: 1s. 2025-10-14 12:40:38.245 | HD Request # 6 | Intraday data download complete for ESZ5.CME. Unique request ID: 15 2025-10-14 12:40:38.245 | Removing historical data download ID 15. 2025-10-14 12:40:38.245 | Real-time Intraday chart data file updates started for ESZ5.CME 2025-10-14 12:40:38.245 | Intraday chart data file opened for ESZ5.CME 2025-10-14 12:40:38.245 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2025-10-14 12:40:38.245 | 2025-10-14 12:40:38.245 | No download requests in the queue to start downloads for. 2025-10-14 12:40:38.305 | Socket (2) | Socket gracefully closed by remote side. 2025-10-14 12:40:38.305 | Socket (2) | Closed. 2025-10-14 12:40:38.370 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:40:38.754 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:40:40.391 | Opened cached Intraday file: C:\SierraChart2\Data\ESZ5.CME.scid. Thread ID: 26764 2025-10-14 12:40:50.184 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. 2025-10-14 12:40:50.184 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0 2025-10-14 12:40:50.184 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 38.79.0.89. 2025-10-14 12:40:50.920 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | Number times message added: 1 2025-10-14 12:40:50.920 | Rithmic Direct - DTC | Wrote file: C:\SierraChart2\RithmicConnections.json. Size: 105509 2025-10-14 12:40:50.921 | Rithmic Direct - DTC | Processed connection points. Count: 452 2025-10-14 12:40:50.921 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call. 2025-10-14 12:40:50.921 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-10-14 12:40:50.921 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed. 2025-10-14 12:44:44.127 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-10-14 12:44:44.867 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-10-14 12:44:45.627 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 12:44:45.672 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:44:45.689 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:45:15.154 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | StartDateTimeForLoadingOrderFills: 2025-10-13 17:00:00 2025-10-14 12:45:15.912 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-10-07 00:00:00 2025-10-14 12:45:16.673 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 12:45:16.718 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 12:45:16.736 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht 2025-10-14 13:11:12.141 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 13:11:12.191 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 13:15:43.981 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 13:15:44.029 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 13:16:01.213 | Unsubscribed from market depth data for ESZ5.CME 2025-10-14 13:16:02.694 | ESZ5.CME/MES?#.CME 30 Min #1 | Reloading chart. 2025-10-14 13:16:03.023 | ESZ5.CME/MESZ5.CME 15 Sec #2 | Reloading chart. 2025-10-14 13:16:05.042 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | StartDateTimeForLoadingOrderFills: 2025-10-13 17:00:00 2025-10-14 13:16:06.086 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Chart data loading complete. 2025-10-14 13:16:06.823 | Requesting market depth updates for: ESZ5.CME if supported. NumLevels=100 2025-10-14 13:16:06.824 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-10-07 00:00:00 2025-10-14 13:16:06.834 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 13:16:06.880 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 13:16:06.897 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Chart data loading complete. 2025-10-14 13:16:06.907 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 13:16:06.987 | Denali Data Feed | Clearing market depth for ESZ5.CME 2025-10-14 13:16:07.029 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 13:16:07.096 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht 2025-10-14 13:59:21.207 | Unsubscribed from market depth data for ESZ5.CME 2025-10-14 13:59:29.094 | ESZ5.CME/MES?#.CME 30 Min #1 | Reloading chart. 2025-10-14 13:59:29.459 | ESZ5.CME/MESZ5.CME 15 Sec #2 | Reloading chart. 2025-10-14 13:59:31.212 | Requesting market depth updates for: ESZ5.CME if supported. NumLevels=100 2025-10-14 13:59:31.386 | Denali Data Feed | Clearing market depth for ESZ5.CME 2025-10-14 13:59:32.243 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | StartDateTimeForLoadingOrderFills: 2025-10-13 17:00:00 2025-10-14 13:59:33.242 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Chart data loading complete. 2025-10-14 13:59:33.937 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-10-07 00:00:00 2025-10-14 13:59:33.947 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 13:59:33.994 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 13:59:34.011 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Chart data loading complete. 2025-10-14 13:59:34.022 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 13:59:34.123 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht 2025-10-14 13:59:34.917 | ESZ5.CME/MES?#.CME[M] 30 Min #1 | Study: -ET Price Rejector Pro | Making HTTP request. 2025-10-14 13:59:34.962 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Bot 13.1Cht.Cht 2025-10-14 13:59:34.979 | ESZ5.CME/MESZ5.CME[M] 15 Sec #2 | Performing a full recalculation because it has been tagged. Chartbook: Bot 13.1Cht.Cht |
| [2025-10-14 20:03:07] |
| User379029 - Posts: 4 |
2025-10-14 12:38:45.247 | Rithmic Direct - DTC | Requesting trade accounts from server. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-52. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-52. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-51. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-51. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-50. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-50. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-49. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-49. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-48. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-48. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-47. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-47. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-46. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-46. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-45. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-45. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-44. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-44. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-43. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-43. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent order fills Date-Time for Trade Account: BX25193-41. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: BX25193-41. 2025-10-14 12:38:45.317 | Rithmic Direct - DTC | Received 11 accounts from service. 2025-10-14 12:38:45.352 | TradeActivity files query time: 0.034254 seconds. Entries: 0. BeginDateTimeUTC: 00:00:00.000. Outstanding queries: 21 2025-10-14 12:38:45.352 | Rithmic Direct - DTC | Requesting historical order fills for account BX25193-52. Start Date-Time UTC: 2025-06-12 17:38:45 2025-10-14 12:38:45.373 | TradeActivity files query time: 0.021781 seconds. Entries: 0. BeginDateTimeUTC: 00:00:00.000. Outstanding queries: 20 2025-10-14 12:38:45.374 | Rithmic Direct - DTC | Requesting historical account balances for account BX25193-52. Start date-time UTC: 2025-06-12 17:38:45 2025-10-14 12:38:45.395 | TradeActivity files query time: 0.021265 seconds. Entries: 0. BeginDateTimeUTC: 00:00:00.000. Outstanding queries: 19 2025-10-14 12:38:45.395 | Rithmic Direct - DTC | Requesting historical order fills for account BX25193-51. Start Date-Time UTC: 2025-06-12 17:38:45 2025-10-14 12:38:45.411 | Rithmic Direct - DTC | Received 0 order fills for account: BX25193-52. 2025-10-14 12:38:45.416 | TradeActivity files query time: 0.021217 seconds. Entries: 0. BeginDateTimeUTC: 00:00:00.000. Outstanding queries: 18 2025-10-14 12:38:45.416 | Rithmic Direct - DTC | Requesting historical account balances for account BX25193-51. Start date-time UTC: 2025-06-12 17:38:45 2025-10-14 12:38:45.437 | TradeActivity files query time: 0.020627 seconds. Entries: 0. BeginDateTimeUTC: 00:00:00.000. Outstanding queries: 17 2025-10-14 12:38:45.437 | Rithmic Direct - DTC | Requesting historical order fills for account BX25193-50. Start Date-Time UTC: 2025-06-12 17:38:45 2025-10-14 12:38:45.449 | Rithmic Direct - DTC | Received 0 order fills for account: BX25193-51. 2025-10-14 12:38:45.457 | TradeActivity files query time: 0.020893 seconds. Entries: 0. BeginDateTimeUTC: 00:00:00.000. Outstanding queries: 16 2025-10-14 12:38:45.458 | Rithmic Direct - DTC | Requesting historical account balances for account BX25193-50. Start date-time UTC: 2025-06-12 17:38:45 2025-10-14 12:38:45.478 | TradeActivity files query time: 0.020566 seconds. Entries: 0. BeginDateTimeUTC: 00:00:00.000. Outstanding queries: 15 |
| [2025-10-14 20:13:55] |
| John - SC Support - Posts: 48555 |
There is nothing logged from the study, so there does not appear to be anything in particular wrong. Please get us that Chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
