Date/Time: Wed, 25 Nov 2026 16:25:18 +0000
Numbers Bars Calculated Values - Volume Coloring Reflective of Bar Close
View Count: 405
| [2025-10-14 15:03:27] |
| GrowingTomatoes - Posts: 3 |
Hi Support, Would there be a way to color any of the NBCV subgraphs representing volume (i.e SG2, SG6, SG7, SG13) to use both Range Up and Range Down colors based on whether a bar closed up or down? To clarify, it is my understanding that any volume related subgraphs currently only support coloring in Range Up colors. Perhaps I'm missing something. It would be useful to visualize a down bar close with significant volume highlighted in Range Down colors alongside other significant subgraph values. I am aware the value would still be positive, I'm only referring to the Background coloring. Your help is greatly appreciated! Thank You, Jacob |
| [2025-10-14 16:53:20] |
This is not currently available. We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
