Date/Time: Wed, 25 Nov 2026 16:25:16 +0000
US Consolidated Tape search
View Count: 383
| [2025-10-13 19:24:08] |
| Cesium - Posts: 179 |
Hello, For MSFT for example, in us equities consolidated tape, search by symbol, I get no window popup with search results. In top right, i see, [requested additional symbols] Search works for other feeds, but not in cons. tape Thank You |
| [2025-10-13 21:11:02] |
This is odd. We have attached a file to show that we are getting the window, so there isn't any specific issue that we know of occurring with this. Our best guess is that the window that is coming up may be off the edge of the monitor, so you are not able to view it. Please select "Window >> Reset Windows" and then try again and see if that resolves it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-13 21:13:39] |
Will the search work when connected to rithmic but using denali
| [2025-10-13 22:31:13] |
| Sierra_Chart Engineering - Posts: 25481 |
The first thing that we need you to do, this is essential, is to update to the current version. Instructions: Software Download: Fast Update And yes, the search will work when using Rithmic. But we are unable to test this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
