Date/Time: Wed, 25 Nov 2026 16:25:17 +0000
Sub chart Separator Line
View Count: 484
[2025-10-13 16:42:34]
mlurski - Posts: 7
i cant find where to change the color of the Sub chart Separator Line. Right now there is either no lone at all or its color is white. Does the line display across the entire window or just on the right margin?
[2025-10-13 17:32:32]
JohnR - User831573 - Posts: 340
On a single chart or using global settings.
Chart -> Graphics Settings -> Region Dividing Line
Hope this helps
JohnR
Date Time Of Last Edit: 2025-10-13 17:32:57
imageSC-RegionDividerLine.jpg / V - Attached On 2025-10-13 17:31:45 UTC - Size: 120.62 KB - 123 views
[2025-10-14 15:36:04]
mlurski - Posts: 7
this has no effect on the chart
https://www.sierrachart.com/image.php?Image=1760456149984.png
[2025-10-14 16:55:25]
Exactly what are you referring to? What is the "Sub Chart Separator Line"?
If you are referring to the Region Dividing Line, then per the image you attached in your last post, you do not have the Region Dividing Lines being displayed. Refer to the following:
Chart Settings: Display Region Dividing Lines (Chart >> Chart Settings >> Grid menu)
