Date/Time: Wed, 25 Nov 2026 22:26:18 +0000
Intraday Charts: Quarterly and Yearly Bar Period Types missing
View Count: 676
[2025-10-13 16:06:19]
User722856 - Posts: 81
Hello Sierra Team,
Situation:
When working with intraday charts (Chart Data Type: Intraday Chart Only), I want to view Weekly, Quarterly, and Yearly timeframes while maintaining intraday data rather than switching to Historical Daily data.
Currently:
-Weekly bars: Require manually entering 7-0-0 in Days-Mins-Secs format AND setting Chart Settings >> Use Date Range >> From to a specific Sunday date - this is cumbersome but works
-Monthly bars: Have a dedicated "Monthly Bars" option in the Bar Period Type dropdown - this works perfectly
-Quarterly bars: I tried using "3 months" as a workaround but this does not work correctly - bars are not properly aligned to calendar quarters
-Yearly bars: I tried using "12 months" as a workaround but this does not work correctly - bars are not properly aligned to calendar years
Am i doing it wrong, or is this not supported on intraday Charts ?
Historical charts are not an option for me, becasue i have studies which need live data.
Thanks in advance for your answer.
Regards
[2025-10-13 17:43:21]
Sierra_Chart Engineering - Posts: 25484
The solution in this case also is to Use Date Range and set, the date to the start of a quarter or the start of a year. It will not work 100% perfect but reasonably close.
Date Time Of Last Edit: 2025-10-13 22:43:18
[2025-10-14 11:10:43]
Thank you for the workaround suggestion.
The Date Range approach doesn't align bars to calendar quarters/years - bars form based on loaded data, not Q1/Q2/Q3/Q4 or Jan-Dec boundaries.
Observation:
Bar Period Type already has Monthly Bars (works perfectly). Weekly/Quarterly/Yearly would complete the standard D/W/M/Q/Y timeframe set using the same implementation pattern.
Since Monthly Bars infrastructure exists, adding the other standard timeframes would resolve the inconsistency.
Thanks for considering.
[2026-01-19 18:37:02]
Hello Sierra Team,
Following up after 3 months.
I've tested the Date Range workaround extensively and it does not work for Weekly/Quarterly/Yearly bars on Intraday Chart Only:
Problem: Setting Date Range to week/quarter/year start does not create calendar-aligned bars.
Question: Is there a working method to achieve calendar-aligned Quarterly/Yearly bars on Intraday Chart Only, or is this functionality not currently supported?
Thanks for clarification.
Date Time Of Last Edit: 2026-01-19 18:38:03
[2026-01-19 22:02:35]
This is not currently supported, hence the reason for the "Workaround" that was given previously.
This thread was already noted as a Feature Request. We can not say when we would get to any particular request.
