Date/Time: Wed, 25 Nov 2026 16:15:16 +0000
charts not working
View Count: 350
| [2025-10-13 13:34:43] |
| User968016 - Posts: 4 |
My charts have frozen and will not work. The messages are as follows: "Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPZ25. ID:1 Click for symbol information" and "Historical Intraday Data Download Failed Historical data only supported with Sierra Chart data feed" Can you help? Kendall Neufeld |
| [2025-10-13 14:16:19] |
| Sierra_Chart Engineering - Posts: 25481 |
Activate the CME exchange that you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Depending upon which exchange you activate, you may have to add additional credit to your Sierra Chart account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
